Here are a few things we have found after upgrading from ABS 2004 to ABS 2006:
Terminal - Flow Arrows: in 2004 we could select diffuser and see the grips for the flow arrows and use them to move the arrows to avoid "graphic overlap" with other stuff.
Problem with custom duct sizes: In 2004, when adding duct, we could enter any custom size. In 2006, we enter the custom size and then when we start to draw we get an error indicating something about the "shape or connection type not being in the current catalog".
Problem with Catalog Regeneration: we get a message from the Comm. Center indicating that a catalog needs to be regenerated. When we click on this we get an error realted to file permissions. This we regenerate catalogs manually from the pull-down menu it seems to work fine. FYI: we have these files on a network drive with several users pointing to them.
Any thoughts or help on this would be appreciated.
