What is the easiest way to create a set of stairs that has a simple S pattern?
Sketch out the center of the stair, then use the run tool and select the curved run and use SC to select the center of the arc for the the run you sketched out., then repeat for the other half of the curve.
Scott D. Brown, AIA
BECK
