Results 1 to 10 of 14
Thread: How to connect data in Excel to Block inside Modelspace
    2006-03
    14
    Question How to connect data in Excel to Block inside Modelspace
    hello. i have a problem here.i have an application where it can find block inside drwg,give the qty and place these report in the drwg.
    purpose :
    create an application to
    a)count block quantity
    b)extract block name and block graphical image
    c)open file(excel) which store the block description ("ID No","height","weight","symbol ","Qty","Block name")
    d)list all the block descriptions inside a table-like.
    can anyone show me how to pform this application?
    is it complicated?if it is,can u suggest anythg else?'
    1) can dbconnect connect the "BLOCK" inside drwg to the"EXTERNAL DATABASE ,like MSAccess/Excel for example?can sum1 show me how?code example,plz?
    2)i have a block type of plant named =" havea brasiliensis" which is stored in a plant file.
    is it possibble for me to extrct the block name with the image for the block altogether ?if possibble,then how?
    but..if it not possible, can sum1 here suggest to me in what way can i get the image represented the block ?because i need to putit inside the table altogether with the "Block Name"
    3)i have tried a code where the first time it executed successfully.But at the second time,it gave me an error .can sumone please tell me how to fix the error?i will attach below.hope to share with all of you out there.im really not an expert in this filed.im a very new beginner in this.really appreciate for any help.
    i really hope sumone out there can help me.please please..i really really need a help.i'm very begginer in this creating application using vb and autocad.please..any help/suggesstion would be great;thanks a lot.
    2002-02
    Kansas
    482
    Default Re: How to connect data in Excel to Block inside Modelspace
    the first time you run the program the selectionset ONLYBLOCKS is not in the drawing the next time you run the program it is so you get a error
    Set objnewss = objDoc.SelectionSets.Add("ONLYBLOCKS")
    change the code to
    On Error Resume Next
    Set objnewss = objDoc.SelectionSets("ONLYBLOCKS")
    On Error GoTo 0
    this way if the selectionset is in the drawing it will just do the next line and set objenewss to the selectionset
    you should add this code before you use the selectionset or any object in the old selectionset will stall be there
    objnewss.Clear
    change
    Dim objnewss As Object '''this line caused an error.why is it?.plz correct it.
    to this
    Dim objnewss As AcadSelectionSet
    Note:
    update to 2011
    I am using ADT 2007 08/06/2008
    PS. If you use any Code I post or Down Load Attachment I would like to know if it was helpful. So please post reply to this thread, on how you use the code or down load. Thank You
    2006-03
    14
    Cool Re: How to connect data in Excel to Block inside Modelspace
    So thank you to u...i will try the codes and see what happen.i'll tell you the results tomorrow.Thanks a lot.
    2006-03
    14
    Unhappy Re: How to connect data in Excel to Block inside Modelspace
    i already used it and it succeed but when i close the AutoCAD, i try to run the code again and it wont work...please help
    2006-03
    14
    Set objnewss.clear
    On Error GoTo 0
    An error accured after "On Error Resume Next" please help
    tq
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,217
    Quote Originally Posted by i_len2884
    Set objnewss.clear
    On Error GoTo 0
    tq
    Maybe this will work for you:
        Dim objSelColl As AcadSelectionSets
      With ThisDrawing
        Set objSelColl = .SelectionSets
        For Each objnewss In objSelColl
          If objnewss.Name = "ONLYBLOCKS" Then
            objSelColl.Item("ONLYBLOCKS").Delete
            Exit For
          End If
        Next objnewss
        Set objnewss = objSelColl.Add("ONLYBLOCKS")
      End With
    f.
    2006-03
    14
    hi fixo,
    thanks so much that u helped me with your code.my code can run successfully now.even after i close the autocad and try to run it again,it works successfully.thank you.
    i wonder if you could help me with the data base connection.
    here my code:
    dim con as adodb.connection
    dim rsdata as adodb.recordset
    con.CursorLocation = adUseClient
    con.open"Provider =Microsoft.Jet.OLEDB.4.0;Data Source...."
    ' Process each block in the selection Set objnewss
       For Each objEntity In objnewss
          For intRowCounter = 0 To lstResults.Rows - 1
            'Set the Row to the Counter
            lstResults.Row = intRowCounter
            ' Set the Colum to block name
            lstResults.Col = 0
            ' check for a match of the Block name and the text Value in the grid
            If objEntity.Name = lstResults.Text Then
              ' set the Column to Count
              lstResults.Col = 1
              ' add one to the Quantity in the Count Column
              lstResults.Text = CDbl(lstResults.Text) + 1
              GoTo ExitProcessing
            End If
          Next
            ' addition of New block to the Flex grid
            ' set the rowlocation to the number of current rows..
            '(0 = 1 in grid world)
            intRowLocation = lstResults.Rows
            ' add a row to the Results FlexGrid
            lstResults.Rows = lstResults.Rows + 1
            lstResults.Row = intRowLocation     ' Setup the Row location
            lstResults.Col = intColBlock        ' Set the Column to the Block colum
            lstResults.Text = objEntity.Name    ' Place the Block text name into the FlexGrid
            rsdata.open"select from MyTable where TreeName ="+lstResults.text,con,adopenstatic,adlockReadonly,adcmdtext
    ''''how to code if lstResults.text = TreeName then insert Quantity into MyTable?
    ''''how to Select * from MyTable (after inserted Quantity) and display in the lstResults.grid?
           lstResults.Col = intColCount        ' Set the Column to the Count column
            lstResults.Text = "1"               ' Place "1" into the FlexGrid in the count column
    ExitProcessing:
     ' end of for
      Next
      ' sort the FlexGrid on the block column
      lstResults.Sort = flexSortGenericAscending ' Sort the FlexGrid Assending
      ' Make the FlexGrid Visible
      lstResults.Visible = True
        ' make the Remove button and Place button enabled or disabled
        If lstResults.Rows <= 1 Then
           cmdRemove.Enabled = False
           cmdMtextPlace.Enabled = False
           Else
           cmdRemove.Enabled = True
           cmdMtextPlace.Enabled = True
        End If
    any help from you out there would be really great.i've been doing this part for 2 weeks already and havent got any clue frm anyone.please sumone out there help me.im clueless..Thanks for sharing your thoughts.Code sample would be better.Thanks.
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    Last edited by Opie; 2006-04-12 at 05:33 PM. Reason: [CODE] tags added, see moderator comment
    2005-05
    Pietari, Venäjä
    1,217
    Sorry buddy Ican't to help you with it
    because I am newbee in VBA too and I haven't in my
    Windows FlexGrid.ocx or MsFlexGrid.ocx files to work
    with Flexgrid form
    f.
    2002-02
    Kansas
    482
    Set objnewss.clear
    On Error GoTo 0
    tq
    should be
    On Error GoTo 0
    Set objnewss.clear
    Note:
    update to 2011
    2006-03
    14
    Wink Re: How to connect data in Excel to Block inside Modelspace
    thanks..it works..
    how can i store the block name and the quantity i got from the resultgrid.text into the access database in the field (blockname and quantity)?
    rsplant.open "insert into mytable (blockname) values= "&resultgrid.text&con,adopendynamic,adlockoptimistic,adcmdtable
    rsplant.open "insert into mytable (quantity) values= "&resultgrid.text&con,adopendynamic,adlockoptimistic,adcmdtable
    and one more thing..how can i search into the Access database for the same blockname(resultgrid.text) i get from the autocad?
    if the matched name found,how to select the row and put it display in the resultgrid?
    i would appreciate for a sample code.thanks..
  1. Can't connect data table to excel spreadsheet
    By glenn22 in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-05-18, 03:16 PM
  2. Extract Title Block Attribute Data to Excel
    By bzrqmy in forum AutoCAD Customization
    Last Post: 2008-12-03, 07:57 AM
  3. Populate Attirbute Block data from Excel
    By avn in forum AutoCAD General
    Last Post: 2006-07-07, 04:56 PM
  4. I am unable to connect excel to AutoCAD
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-03-16, 11:03 PM
  5. Replies: 2
    Last Post: 2005-07-27, 05:45 PM
