hello. i have a problem here.i have an application where it can find block inside drwg,give the qty and place these report in the drwg.
purpose :
create an application to
a)count block quantity
b)extract block name and block graphical image
c)open file(excel) which store the block description ("ID No","height","weight","symbol ","Qty","Block name")
d)list all the block descriptions inside a table-like.
can anyone show me how to pform this application?
is it complicated?if it is,can u suggest anythg else?'
1) can dbconnect connect the "BLOCK" inside drwg to the"EXTERNAL DATABASE ,like MSAccess/Excel for example?can sum1 show me how?code example,plz?
2)i have a block type of plant named =" havea brasiliensis" which is stored in a plant file.
is it possibble for me to extrct the block name with the image for the block altogether ?if possibble,then how?
but..if it not possible, can sum1 here suggest to me in what way can i get the image represented the block ?because i need to putit inside the table altogether with the "Block Name"
3)i have tried a code where the first time it executed successfully.But at the second time,it gave me an error .can sumone please tell me how to fix the error?i will attach below.hope to share with all of you out there.im really not an expert in this filed.im a very new beginner in this.really appreciate for any help.
i really hope sumone out there can help me.please please..i really really need a help.i'm very begginer in this creating application using vb and autocad.please..any help/suggesstion would be great;thanks a lot.
