Thread: dimension to Rough Width
    2006-02
    19
    Question dimension to Rough Width
    Is there a way to automatically dimension walls to
    rough width of doors?
    the dimension command ignores the opening and seems to use
    Width parameter of doors.
    Maybe this should be in the wish list if it is not possible
    In the dimension-options command there would be 3 options
    measure openings to
    center
    width
    rough width
    2005-05
    17
    2
    Default Re: dimension to Rough Width
    Hi Tom,
    If I remember rightly the rough width and height are not parameters used in the families as a default, they are there in the template for what ever reason. So unless your family employs the use of these as contraints etc and you have reference planes then you should be able to tab to the required element to dimension to.
    All AUGI, all the time cphubb's Avatar
    2003-11
    Seattle
    691
    That is generally correct leediggle.
    You will need to add some reference planes to the door family to represent the RO and make them a strong reference so dimensions will find them in the model. You still may need to tab to see the reference since the actual opening is also a Strong Reference. You can control the location of the RO planes by making them EQ to the center of the door, dimensioning them and attaching the RO parameter to the dimension. Will schedule as it does now but can be dimensioned either way.
    2006-02
    19
    Thanks for your help!
    I changed the reference to strong and now i can manually select them.
    However here in Norway all windows and doors are dimensioned to
    RO in plans so i dont want to do it manually.
    i guess i will have to use Width as rough width and make a parameter with
    the true door/window size for schedules
  1. How to grey-out Rough Width and Rough Height parameters
    By Scott Hopkins in forum Revit Architecture - Tips & Tricks
    Last Post: 2013-09-15, 11:31 PM
  2. Dimension to rough openings
    By Denis01 in forum Revit Architecture - General
    Last Post: 2010-08-18, 01:53 AM
  3. AEC dimension showing Height and Width
    By burchd in forum ACA General
    Last Post: 2008-02-06, 01:27 PM
  4. Changing dimension text width
    By jsr13 in forum Revit Structure - General
    Last Post: 2007-01-30, 07:04 PM
  5. Dimension text width factor
    By barathd in forum Revit Architecture - Wish List
    Last Post: 2006-06-07, 01:10 PM
