; Program Parameters File For AutoCAD 2005
; External Command and Command Alias Definitions
; Copyright (C) 1997-2004 by Autodesk, Inc.
; Each time you open a new or existing drawing, AutoCAD searches
; the support path and reads the first acad.pgp file that it finds.
; -- External Commands --
; While AutoCAD is running, you can invoke other programs or utilities
; such Windows system commands, utilities, and applications.
; You define external commands by specifying a command name to be used
; from the AutoCAD command prompt and an executable command string
; that is passed to the operating system.
; -- Command Aliases --
; The Command Aliases section of this file provides default settings for
; AutoCAD command shortcuts. Note: It is not recommended that you directly
; modify this section of the PGP file., as any changes you make to this section of the
; file will not migrate successfully if you upgrade your AutoCAD to a
; newer version. Instead, make changes to the new
; User Defined Command Aliases
; section towards the end of this file.
; -- User Defined Command Aliases --
; You can abbreviate frequently used AutoCAD commands by defining
; aliases for them in the User Defined Command Aliases section of acad.pgp.
; You can create a command alias for any AutoCAD command,
; device driver command, or external command.
; Recommendation: back up this file before editing it. To ensure that
; any changes you make to PGP settings can successfully be migrated
; when you upgrade to the next version of AutoCAD, it is suggested that
; you make any changes to the default settings in the User Defined Command
; Aliases section at the end of this file.
; External command format:
; <Command name>,[<Shell request>],<Bit flag>,[*]<Prompt>,
; The bits of the bit flag have the following meanings:
; Bit 1: if set, don't wait for the application to finish
; Bit 2: if set, run the application minimized
; Bit 4: if set, run the application "hidden"
; Bit 8: if set, put the argument string in quotes
; Fill the "bit flag" field with the sum of the desired bits.
; Bits 2 and 4 are mutually exclusive; if both are specified, only
; the 2 bit is used. The most useful values are likely to be 0
; (start the application and wait for it to finish), 1 (start the
; application and don't wait), 3 (minimize and don't wait), and 5
; (hide and don't wait). Values of 2 and 4 should normally be avoided,
; as they make AutoCAD unavailable until the application has completed.
; Bit 8 allows commands like DEL to work properly with filenames that
; have spaces such as "long filename.dwg". Note that this will interfere
; with passing space delimited lists of file names to these same commands.
; If you prefer multiplefile support to using long file names, turn off
; the "8" bit in those commands.
; Examples of external commands for command windows
CATALOG, DIR /W, 8,File specification: ,
DEL, DEL, 8,File to delete: ,
DIR, DIR, 8,File specification: ,
EDIT, START EDIT, 9,File to edit: ,
SH, , 1,*OS Command: ,
SHELL, , 1,*OS Command: ,
START, START, 1,*Application to start: ,
TYPE, TYPE, 8,File to list: ,
; Examples of external commands for Windows
; See also the (STARTAPP) AutoLISP function for an alternative method.
EXPLORER, START EXPLORER, 1,,
NOTEPAD, START NOTEPAD, 1,*File to edit: ,
PBRUSH, START PBRUSH, 1,,
; Command alias format:
; <Alias>,*<Full command name>
; The following are guidelines for creating new command aliases.
; 1. An alias should reduce a command by at least two characters.
; Commands with a control key equivalent, status bar button,
; or function key do not require a command alias.
; Examples: Control N, O, P, and S for New, Open, Print, Save.
; 2. Try the first character of the command, then try the first two,
; then the first three.
; 3. Once an alias is defined, add suffixes for related aliases:
; Examples: R for Redraw, RA for Redrawall, L for Line, LT for
; Linetype.
; 4. Use a hyphen to differentiate between command line and dialog
; box commands.
; Example: B for Block, -B for -Block.
; Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
; -- Sample aliases for AutoCAD commands --
; These examples include most frequently used commands. NOTE: It is recommended
; that you not make any changes to this section of the PGP file to ensure the
; proper migration of your customizations when you upgrade to the next version of
; AutoCAD. The aliases listed in this section are repeated in the User Custom
; Settings section at the end of this file, which can safely be edited while
; ensuring your changes will successfully migrate.
