I want to place a smaller VP over a larger VP and have the smaller one mask/hide what under it in the larger VP.
Is this possible?
Is this possible?
You will probably want to do a VCLIP of the larger viewport having a boundary that goes around the smaller viewport.
Ok, Tried that... I'm picking the larger VP, Boundary around the smaller VP, Right Click and the larger VP is clipped around the smaller.... I want the area inside the boundary to clip on the larger VP not the area outside the boundary....
You may need to use a region to clip it to your desired shape. Can you post an image or the drawing?
No can Do.....Originally Posted by Opie
I will try the region....
HiOriginally Posted by thomas.stright
Does the following work for your needs...
Floating Viewport with a hole cut out...
Have a good one, Mike
