Results 1 to 10 of 14
Thread: Unresolved Xrefs
    2005-06
    22
    Default Unresolved Xrefs
    Hi All,
    Have a bit if a problem with xrefs. Since upgrading a couple of seats to 2007 they will often list some (not all) of the xrefs within a drawing as "unresolved". The xref then needs reloading but after saving and the opening again is still not visible and still listed in the manager as "unresolved". However, if I open the drawing in 2006 the xref loads correctly. As you can imagine this is extremely frustrating so if anyone can shed some light on this I'd be extremely grateful.
    Trev.
    Active Member wolfgrrlone's Avatar
    2003-05
    54
    Default Re: Unresolved Xrefs
    If you open each of the xrefs within 2007 and save them, it will allow them to load in the original dwg. The xref's need to be updated to 2007 and once you open and save them, they will be.
    Active Member treb's Avatar
    2002-07
    Toronto
    75
    so a company is supposed to batch convert 1000's of blocks or xrefs to 2007?
    thats justs dumb
    2003-05
    54
    It has been this was since 2006 was introduced - if you opened 2005 dwgs with xrefs in 2006, you had to do the same thing.
    Don't kill the messenger, treb. I was trying to be of assistance to you.
    2002-07
    Toronto
    75
    Quote Originally Posted by wolfgrrlone
    no shooting the messenger! and thanx.
    the company I work for is still stuck in 2004, so we havent encounter this problem.
    but when we do switch, I wil hire a college student to convert everything.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    I've never had this problem. I still have users that are using different versions with no problems of unresolved xrefs.
    2005-10
    80
    Quote Originally Posted by treb
    thats justs dumb
    If you are using 04 then you may want to prepare to batch convert any blocks you may use based on INSUNITS...
    13,656
    Question Re: Unresolved Xrefs
    Hi
    Please explain, seeing as AutoCAD 2004, 2005 and 2006 all shared the same DWG format.
    Sorry, I am with Richard on this one.
    Have a good one, Mike
    2005-06
    22
    Unhappy Re: Unresolved Xrefs
    Before this runs off on a tangent I've tried saving the xref file in 2007 format as well and it's made no difference whatsoever...............
    13,656
    Quote Originally Posted by trevor.tizard
    Hi
    How is the Path for this misbehaving Xref saved...
    Save Path
    OR
    Relative Path
  1. Replies: 0
    Last Post: 2010-11-15, 04:51 PM
  2. Unresolved Xref
    By asmckee in forum AutoCAD General
    Last Post: 2010-03-19, 06:52 AM
  3. Unresolved Xrefs
    By christopheram85 in forum AutoCAD General
    Last Post: 2008-05-21, 02:57 PM
  4. xref unresolved
    By crbickel in forum ACA General
    Last Post: 2007-03-28, 12:12 AM
  5. Unresolved Xref
    By Shizzjr in forum AutoCAD General
    Last Post: 2005-12-19, 05:17 PM
