Thread: Checking if something is nothing??
    2003-01
    Currently Brisbane, Australia
    40
    Default Checking if something is nothing??
    G'day All,
    Am having a crack at this VBA thing and have gone alright today. Iam trying to create a polyline
    where the user can select as many points as they want and when they finish they type T to finish.
    But I have two problems:
    1. The way I have done it is to have a varible for the first point, the second point, and a variable to take all the other points picked by the user (varTendonPoint). But on my first go into my loop it wont have a value for use to draw a line from last point. I tried testing it to nothing but that doesnt seem to work...Is there a more elegant way?
    2. If I type T at the command line it doesnt terminate the polyline it just says invalid option....I thought that if I typed T it would produce an error and I could get out....hmmm lost with using this error stuff in VBA any pointers. It seems pretty clunky.
    Cheers for any help,
    Scott
    On error resume next
    ThisDrawing.Utility.InitializeUserInput 128, "T t"
    	Do Until Err.Number <> 0
    		'If this is the first point after the second point then use the second point to draw the previous line from
    		If varTendonPoint = Nothing Then
    			varTendonPoint = ThisDrawing.Utility.GetPoint(varSecondTendonPoint, "Specify next tendon point or [<T>erminate tendon]:")
    		'Otherwise use the last point that was picked to draw the previous line from
    		Else
    			varTendonPoint = ThisDrawing.Utility.GetPoint(varTendonPoint, "Specify next tendon point or [<T>erminate tendon]:")
    		End If
    		ReDim Preserve dblTendonPoints(UBound(dblTendonPoints) + 2)
    		dblTendonPoints(UBound(dblTendonPoints) - 1) = varTendonPoint(0): dblTendonPoints(UBound(dblTendonPoints)) = varTendonPoint(1)
    	Loop
    2002-02
    Kansas
    487
    Default Re: Checking if something is nothing??
    ThisDrawing.Utility.InitializeUserInput need to be call before each call to ThisDrawing.Utility.GetPoint it only good for on call to getpoint
    and you can use a Collection to save you points in
    you should use IsEmpty function
    if IsEmpty(varTendonPoint ) then
    NOT
    here the code I would use
    Dim x, y
    Dim c As New Collection
    'C IS A COLLECTION OF POINTS
    On Error Resume Next
    Do While True
    x = x + 1
    If x = 1 Then
    y = ThisDrawing.Utility.GetPoint(, "Point  " & CStr(x))
    Else
    y = ThisDrawing.Utility.GetPoint(c(c.Count), "Point  " & CStr(x))
    End If
    If Err Then Exit Do
    c.Add y
    Loop
    this code will next on any error of the in put data need to and code to check for keyword in put
    2015-12
    Central Oregon
    591
    Here's a sample I posted for someone a while back that does basically what you want...except it is for 3dpoly's. Modify as needed for LW poly's.... mainly the Dim'ed object and LW plines only use x & y. By using this method it allows you to the pline as you draw, a la the pline command.
    Sub testpoly()
    Dim vpick As Variant
    Dim dCoords() As Double
    Dim I As Long
    Dim oPoly As Acad3DPolyline
    vpick = ThisDrawing.Utility.GetPoint(, vbCr & "First point: ")
    If Err = 0 Then
        ReDim dCoords(2)
        dCoords(I) = vpick(0): dCoords(I + 1) = vpick(1): dCoords(I + 2) =
    vpick(2)
            I = I + 3
            vpick = ThisDrawing.Utility.GetPoint(vpick, vbCr & "..next point: ")
            ReDim Preserve dCoords(UBound(dCoords) + 3)
    vpick(2)
            If oPoly Is Nothing Then
                Set oPoly = ThisDrawing.ModelSpace.Add3DPoly(dCoords)
            Else
                oPoly.Coordinates = dCoords
            End If
        Loop
    End If
    End Sub
  1. Checking
    By Bill Hyland in forum New Forum Users (Non technical)
    Last Post: 2006-04-11, 05:00 PM
  2. checking out an .ipt
    By kjolly in forum Inventor - General
    Last Post: 2005-09-21, 10:29 PM
  3. Checking in
    By eclipse1995gsx in forum New Forum Users (Non technical)
    Last Post: 2005-06-16, 06:39 PM
  4. Checking it out
    By rsmith.84160 in forum New Forum Users (Non technical)
    Last Post: 2005-03-14, 04:01 PM
