mdaddario
I have many length variable parts in our library that I would like to be able to copy out of the library to assembly templates for a job. Use the adaptivity for the part in an assembly to extrude from/to in the context of the assembly however there is no parameter that defines the length once I make the from/to extrude.
I tried using a driven dimension on a projected edge of a sketch along one of the extruded but the projection is not associative therefore does not update when the adaptive part changes length.
Is there a way to extract the profile extrude length from the model once the from/to extrude command is invoked?
Thanks in advance!
Mike D.
