Results 1 to 7 of 7
Thread: Parameters - Additional
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    753
    Default Parameters - Additional
    Is it possible to add a parameter (shared or some other method) to Walls so that I may designate them as Interior or Exterior / bearing or non-bearing? We are working on a conversion from Revit to another software for additional framing design/loading analysis and there doesn't seem to be any way to determine this during the conversion.
    And is there a way to add parameters to the project information parameters list?
    nevermind on the bearing and non-bearing issue, but still need interior/exterior. Would a project parameter (yes/no) be the way to go with this?
    100 Club nrenfro's Avatar
    2003-09
    metro DC
    144
    Default Re: Parameters - Additional
    I am not clear what you are doing with the information, but adding a project parameter may do the trick.
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,224
    Check the type parameters of a wall. There is a "Wall Function" parameter. You can choose from Interior, Exterior, Foundation, Retaining and Soffit.
    HTH
    Brad Novak
    Director of Information Technology
    Gp GOETTSCH PARTNERS
    Chicago, IL
    2003-09
    metro DC
    144
    I knew that that was in their, but could not find it when I was looking for it. Thought that I might have read about it or somthing.
    Upgraging has become so transparent....
    2005-02
    Central PA, USA
    753
    Quote Originally Posted by bowlingbrad
    HTH
    Perfect. Thanks so much.
    Anybody know about how to add parameters to the project info parameters list under the settings menu?
    I could stop if I wanted to The Sweg's Avatar
    2003-09
    Amish Country
    205
    Go to 'settings' menu, and click on Project parameters, click to add one. I believe you can create a new one from in here. Make sure Project parameter is checked and in the right under 'categories', scroll down and place a checkmark in front of 'project information'. It should show up in project info!
    HTH
    Choose not to be offended.
    2005-02
    Central PA, USA
    753
    Thanks again. I was trying to use type instead of instance. The project info category was only available under instance.
    You guys are lightning fast today. Thanks so much.
  1. Unable to add any additional Parameters
    By gdury in forum Revit MEP - Families
    Last Post: 2009-07-16, 02:39 PM
  2. Family Category and Parameters can Additional ones be added
    By jarod.tulanowski in forum Revit Architecture - General
    Last Post: 2005-01-28, 04:59 PM
  3. Project Informtion: Additional Parameters?
    By Chad Smith in forum Revit Architecture - Families
    Last Post: 2003-12-03, 08:02 AM
