I posted some shots of a wood trellis I created. The columns were just downloaded from web (revitcity/revit.com) and added. To create the beams, joists and smalls lattice layer on the very top, I created generic walls and sized them to what I needed, applied a wood material and then grouped and arrayed. The group/array works well for adjusting the trellis size and parameters.
My question is if anybody has created trellis work with actual beams and joists? Would you recommend this way over using generic walls? I used the walls because it was pretty fast to build. Also, with a piece like this, would anyone recommend creating a family or would it be considered to specialized? Please share your Revit management thoughts/ideas.
_mike
