Results 1 to 6 of 6
Thread: How-to Dimension Isometric drawings
    2005-10
    Jacksonville, Florida
    2
    Question How-to Dimension Isometric drawings
    I'm a cad student and cannot figure out how to dimension Isometric drawings properly. I do not know how to format measurements on the same planes as the drawing and am getting some incorrect measurements as well as having to correct the angle the leader lines are on. Does CAD allow measurement on Isometric planes and if so how do I format them or turn them on.
    Mary
    13,618
    Question Re: How-to Dimension Isometric drawings
    Hi
    Does this help...
    ID: TS46712 - Applying an oblique dimension in an isometric view
    Have a good one, Mike
    2005-10
    2
    Default Re: How-to Dimension Isometric drawings
    editing the dimension lines after the fact is pretty much what I have been doing. I was hoping for a setting or format the Cad would know that I am already in Isometric planes and dimension accordingly...
    I really appreciate your in put none the less..
    Mary
    0,0,0 The Origin
    8,569
    Quote Originally Posted by mjpestalitz
    Mary
    If you want to do it the old way, use the Styles and Dimstyles in the attached drawing.
    The method illustrated in Mike's link is easier though.
    John B
    2009-05
    2
    I open drawing iso.dim.dwg, what is TROTATE
    I do not see any setting in auotcad for this
    2009-06
    8
    1 members found this post helpful.
    Hi Kenneth,
    The TROTATE is a sub command in the command DIM. So to set TROTATE first you type in command DIM and at DIM: prompt enter TROTATE then it will ask you the angle. I don't know wher it is in the Dialogue Diplays as I am an old CAD user I use commands.
  1. Isometric Dimension.....
    By somared in forum AutoCAD General
    Last Post: 2014-01-13, 05:51 AM
  2. Best way to do isometric drawings?
    By RyanSS in forum AutoCAD General
    Last Post: 2007-08-05, 11:24 AM
  3. Dimensioning isometric drawings in AutoCAD 2007
    By r.burks in forum AutoCAD General
    Last Post: 2007-05-07, 07:57 PM
  4. Make Isometric Drawings from the Piping Module
    By Inventor Wishes in forum Inventor Wish List
    Last Post: 2006-08-15, 03:00 AM
  5. Isometric Dimension
    By Merlin in forum AutoCAD General
    Last Post: 2005-12-01, 12:14 AM
