Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 72
Thread: New Feature? Two Pick Families?
    2005-03
    200
    Default New Feature? Two Pick Families?
    The "whats new in Revit 9 pdf" mentions modeling sweeps as a enhancement. Whats new with sweeps? Also what do they mean by 3d 2-pick families?
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Default Re: New Feature? Two Pick Families?
    Splines can be in sweep paths and profiles.
    Wes Macaulay LEED AP
    Teck Construction LLP
    Revit 2014 x64 | Win7 x64 | nVidia GT 650M
    Tell Adesk what you think!
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,753
    3D two-pick families are basically sweeps. You could, for instance, line a room with shelving in 3d, just by drawing lines in plan. As you draw the line, the 3d portion is generated. Very cool tool!
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    I'm not familiar with the "two pick" as a type of Revit family, and I use Revit all day long. If it is a sweep why refer to it as a "3d 2-pick family"? I think we already have wall sweeps. What I need to know is what this tool does that we cannot do now. What problem does this solve?
    2001-12
    Irvine, CA
    7,349
    Take a look at the detail component libraries there are a bunch of them. You sketch objects just like a line or wall. Take a plywood detail component, pick two points and the detail is drawn between them. 3D...dentil moulding cornice detail.
    I could stop if I wanted to dfriesen's Avatar
    2003-05
    Vancouver, B.C.
    467
    I was delighted to see a Line Based 2 pick family template, thinking that it would be the answer to my quest to make a hanger/brace as shown attached, but it seems it can only be flat. Am I missing something?
    Daniel Friesen
    I could? I don't think so...
    Member lafe's Avatar
    2004-06
    American Fork, Utah, USA
    36
    I think 2-pick families would be a family which is defined, but the length is changeable, and when you place the family you pick the two end points for it. I haven't messed with it yet to know for sure.
    2003-04
    Chino, CA
    4,753
    Quote Originally Posted by dfriesen
    Did you change your workplane to what ever angle you'd like before placing it?
    Scott D Davis
    Autodesk, Inc.
    I could stop if I wanted to neb1998's Avatar
    2004-06
    Chicago
    373
    Goto detail components and draw sheathing or drywall, you can pick one point where the drywall begins and another where you want it to end and the family fills inbetween automatically...very cool feature.
    Ben Kane
    2005-03
    200
    Quote Originally Posted by neb1998
    Could you post an example? And where do I find this feature(found nothing by searching the help files)?
  1. SEARCH FEATURE FOR FAMILIES
    By Limbatus in forum Revit - Platform
    Last Post: 2011-06-02, 04:57 PM
  2. Ceiling hosted 2-pick families
    By Andre Baros in forum Revit Architecture - Families
    Last Post: 2009-02-28, 03:23 PM
  3. Two Pick Families
    By Andrew Dobson in forum Revit Architecture - Families
    Last Post: 2006-09-20, 11:16 AM
  4. Looking for two pick ductwork families
    By christo4robin in forum Revit Architecture - Families
    Last Post: 2006-06-28, 03:14 PM
