Thread: Extract Attribute Data into a Table
    100 Club KansasCAD's Avatar
    2002-02
    Derby, Kansas
    109
    Question Extract Attribute Data into a Table
    Thank you so much, that fixed it.
    I have a new question so I will first ask it here, and re-ask it in a new post if you don't know or if I don't get a response. How hard, or is it possible, to extract attribute data, including field data from a block (such as Northing and Easting values) directly into an AutoCAD Table?
    Thanks again for the help.
    Daryl
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: Extract Attribute Data into a Table
    Quote Originally Posted by dstandri
    Daryl
    Depending on your AutoCAD version, you could use FIELDS to extract object data. It is a little time consuming, but it is available.
    You could also use the Attribute Extraction tool to create a table of the appropriate information. This may be what you are looking for, but I'm not sure without knowing additional information.
    (P.S. next time just start a new thread. One of the mods for this forum should be along to split this topic off to a new thread.)
  1. Replies: 2
    Last Post: 2009-09-24, 01:31 AM
  2. Extract Title Block Attribute Data to Excel
    By bzrqmy in forum AutoCAD Customization
    Last Post: 2008-12-03, 07:57 AM
  3. Extract attribute
    By sandeep_koodal in forum AutoCAD General
    Last Post: 2008-10-07, 11:17 AM
  4. attribute extract and attribute import
    By rstiles in forum ACA General
    Last Post: 2008-09-12, 02:55 PM
  5. Reversing Attribute Extract
    By martyk in forum AutoCAD General
    Last Post: 2006-01-19, 10:36 PM
