Thread: Room Areas
    Active Member aaronwsmith's Avatar
    2006-04
    Melbourne, Vic, Australia
    95
    Question Room Areas
    Is there a way to enclose an area, which isn't actually fully closed by walls, so that when a room tag is inserted, it only selects the area which you want it to? so maybe some sort of boundary? And maybe this is possibly with outdoor areas, so as to be able to get the total areas of verandah's, porch's etc.
    2003-05
    5,153
    Default Re: Room Areas
    Yes, yes and yes.
    Use Room Separation lines or Area Boundary lines.
    2006-04
    95
    Thanks!! will the dashed separation lines be printed? and if so can they be hidden, so as not to be printed?
    2003-05
    5,153
    Hi Aaron,
    Both line types can be turned off using Vis Graphics - Model Categories > Lines > Area Boundary or Room Separation. ( Otherwise they will print )
    ( Hope Revit is going well for you. )
  1. room areas
    By dedaguanno in forum Revit Architecture - General
    Last Post: 2005-12-01, 04:43 AM
  2. Calculations on Room Areas
    By Scott Womack in forum Facilities Management In Practice
    Last Post: 2005-08-30, 07:32 PM
  3. Calculations on Room Areas
    By Scott Womack in forum Revit Architecture - General
  4. Room Areas in Perspective
    By mnisbett in forum Revit - Rendering
    Last Post: 2004-11-17, 09:16 PM
  5. Room Areas
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2003-10-01, 07:31 AM
