This is important, especially with large firms, so that people can quickly understand what things are. Some things that we have to name:
- File names, local & central
- Families
- Family Types
- Parameters
- Materials
- Rendering textures
- Views
- Sheets
The naming of things has already been thought out by the military. I think we can use what they’ve already devised. I’d replace commas with dashes in Revit where needed. Here are some descriptions of how it’s done there:
The following is typical per mil-t-31000 and mil-c-100.
Noun Name, Modifier, Modifying Phrase - Modifying Phrase, Modifier
Example:
Guide, SHAFT, BUTTERFLY VALVE- .010 INCH OVERSIZE, LOWER
When using the words "ASSEMBLY", "INSTALLATION" or SUBASSEMBLY in a basic name, it appears as the last word in the noun phrase (first part) and may b abbreviated.
Reference: http://www.engineersedge.com/wwwboard/messages/492.html
Title Assignment
When assigning a drawing title, clearly describe the item with the most applicable noun name and, if necessary, additional modifiers.
First Part of Item Name The first part of the item name shall be the noun name. It shall not contain the method of manufacturing, such as casting, forging, machining, etc.
Noun Name
The Noun Name is a noun or a noun phrase that best establishes a basic concept of the item. It describes what the part is and the usage of the part, and not the material or method of fabrication. A compound noun or noun phrase is used only when a single noun is inadequate or ambiguous.
Example
Basic Name
BRACKET PISTON SLIDE RULE SOLDERING IRON
(Noun) (Noun) (Noun Phrase) (Noun Phrase)
First Part Modifiers
When the noun name represents an item to which types, grades, variety, etc., are applicable, the remainder of the first part of the title consists of one or two modifiers. A modifier may be a single word or qualifying phrase. The first modifier serves to narrow the concept established by the basic name. Succeeding modifiers must continue a narrowing concept by expressing a different type of characteristic. A word directly qualifying a modifier precedes the word it qualifies, thereby forming a modifying phrase.
Example: BRACKET, PRESSURE TRANSMITTER The word “PRESSURE” qualifies the word “TRANSMITTER”, thus a qualifying phrase is formed. Also, the modifier is separated from the noun or noun phrase or subsequent modifier by a comma.
Second Part of the Item Name
The second part of the item name may contain the word casting, forging, etc., only when there is a machining drawing as well as a casting, forging, etc., drawing.
Second Part Modifiers
The second part of a title is separated from the first part by a dash (-) and consists of modifiers or modifying phrases as required. Modifiers indicating what an item is (its shape, structure or form) or what an item does (its function) are preferable to modifiers indicating the application (what it is used for) or location (where used) of the item. When two or more drawings in the same major assembly are similar and the parts detailed thereon perform the same general function, they are distinguished by additional modifiers indicating location, position, form, dimensions, etc.
Examples
BRACKET, PRESSURE TRANSMITTER - OUTSIDE, LOWER BRACKET, PRESSURE TRANSMITTER - OUTSIDE, UPPER TUBE ASSY, METAL - FILTER INLET, TURBOPUMP TUBE ASSY, METAL - FILTER DISCHARGE, TURBOPUMP
ITEM NAME ADDITIONAL MODIFIERS (First Part) (Second Part)
GUIDE, SHAFT, BUTTERFLY VALVE-.010 INCH OVERSIZE, LOWER
Noun Name, Modifier, Modifying Phrase, Modifying Phase, Modifier
Title Breakdown
The singular form of the noun or noun phrase shall be used as the basic name, except as follows:
1. Where the only form of the noun is plural. Example: TONGS, SCISSORS. Etc.
2. Multiple single items on the same drawing (Tabulated).
Example: BOLTS, SHIMS, SPACERS, WASHERS, FUSES, CONNECTORS, etc.
(In the parts list of the next assembly, use the singular form of the name).
Noun Abbreviations
When using the word, “ASSEMBLY”, “SUBASSEMBLY” or “INSTALLATION” in a basic name, it appears as the last word in the noun phrase (first part) and may be abbreviated, if space is a problem.
Examples
SWITCH INSTL OR SWITCH INSTALLATION POWER DIVIDER SUBASSY OR POWER DIVIDER SUBASSEMBLY
Ambiguous Noun
An ambiguous noun, or one which designates several classes of items, is not used alone as the basic name, but as part of the noun phrase.
Examples
Acceptable Not Acceptable
TERMINAL BOARD BOARD, TERMINAL
WIRING HARNESS HARNESS, WIRING
SHOCK ABSORBER ABSORBER, SHOCK
When the item is not a container or material, but its basic name involves the use of a noun which ordinarily designates a container or material, use a noun phrase as the basic name.
Examples
JUNCTION BOX BOX, JUNCTION
SOLDERING IRON IRON, SOLDERING
A trademarked or copyrighted name shall not be used as the noun name, except where the technical name is extremely difficult.
Example
“FREON-12” rather than “DICHLORODIFLUORMETHNE”
Drawing Types Included In Title
The following types of drawings shall include the drawing type as the second part of the title:
BLOCK DIAGRAM
DRAWING TREE
INTERCONNECTION DIAGRAM
MANUFACTURING FLOW CHART
SCHEMATIC DIAGRAM
SYSTEM DIAGRAM
WIRING DIAGRAM
Reference & more at: http://www.engineersedge.com/wwwboard/posts/1936.html
Please discuss
