Results 1 to 10 of 10
Thread: No matter which Workspace Profile I select, I get the 3D Modeling Workspace
    I could stop if I wanted to charliep's Avatar
    2003-02
    Northumberland, U.K.
    335
    Default No matter which Workspace Profile I select, I get the 3D Modeling Workspace
    For some reason no matter which workspace profile I select I get the 3D modeling workspace. How can I change the workspaces back to what they should be?
    Regards
    Charlie Priest
    Enterprise Architectural Services Ltd.
    Houston
    7,520
    Default Re: No matter which Workspace Profile I select, I get the 3D Modeling Workspace
    You could reload the "acad.cui" from the \UserDataCache directory.
    2003-02
    335
    Thanks for the tip, but only partial success.
    I checked various settings and found that the default template file was set to 3d.dwt, so changed it to acad.dwt. However, when I change the workspace from 3D modelling to My Workspace, the toolbars etc. change but the workspace remains in 3D perspective.
    Regards
    Charlie Priest
    2001-03
    13,499
    Hi
    See if the following free tutorial from Moss Designs helps...
    How to set 2007 back to AutoCAD 2D mode ( direct link to PDF file ).
    Have a good one, Mike
    Houston
    7,520
    Quote Originally Posted by charliep
    Changing the workspace (toolbar, menu location and visibility) does not change the template drawing or it's view.
    You are expecting it to do something that it was not designed to do.
    2003-02
    335
    Thanks for the reply Mike & R.K. McSwain,
    I think my problem is with understanding the difference between workspace and visual styles. It appears that 2007 defaults to 3D modeling (Acad3D.dwt) to open up and changing to My Workspace does not change the visual style, this seems to have to be done separately.
    As I do most of my work in 2D (also use Revit), having the default template set to acad.dwt will suit me best for now. The visual style and dashboard is something for me to explore when I get a bit of time.
    Regards
    Charlie Priest
    Houston
    7,520
    That is what I was trying to say. The template drawing you load (set in Options, Files tab) is independent of the "workspace".
    I could stop if I wanted to Mamma Jamma's Avatar
    Massachusetts
    336
    Setting to AutoCAD classic isn't doing it...flashes (millisecond) the 2-d, then goes to the 3-d.
    Mamma Jamma
    "Normal is an illusion. What is normal for the spider is chaos for the fly"
    Morticia Addams
    Massachusetts
    336
    Oh, I figured out my problem.
    Tools\Options\Files\Template Settings\Default Template File Name for Qnew\"really long address ending with acad3d.dwt
    Changed it to acad.dwt.
    Then saved my profile (again!)
    Then added the /p "your profile name" switch to my desktop startup icon properties.
    Whew! Got it! Boy was I cursing for a while there!!!
    (I hope it retains it tomorrow)
    Mamma Jamma
    Morticia Addams
    Houston
    7,520
    Quote Originally Posted by lafleur
    That's exactly what I said HERE
  1. Workspace - 3D Modeling option not showing
    By alan.123099 in forum AutoCAD Mechanical - General
    Last Post: 2011-08-25, 09:59 PM
  2. 2011: workspace help
    By JLHConsulting in forum AutoCAD General
    Last Post: 2010-07-01, 11:11 PM
  3. Workspace, CUI and Profile
    By brantf in forum CAD Management - General
    Last Post: 2008-02-14, 07:19 PM
  4. Workspace
    By Ramandeep.Brar in forum Land Desktop - General
    Last Post: 2005-05-04, 02:06 PM
