Hello,
I'm wondering if anyone out there has this same issue w/ Revit Version 9, the problem is as follows:
If you plot a Raster/Color sheet using Raster Processing to the plotter in version 8.1 it comes out just fine.
I upgraded this same file to version 9 and tried to print the same sheet in Raster/Color sheet using Raster Processing and it crashes our entire offices NETWORK print spooler,(This is not good times).
We have HP Designjet 1055CM with 256 mb RAM and the latest driver 4.67.
Autodesk has told me to go to Start\Printers and Faxes\right click on the plotter in question\Printing Preferences\Advanced Tab\and change the processing from "in Printer" to "in Computer". This worked for some people's plots but not everyone's, some people it would just freeze in the plotter and plot a black blob. And it takes forever to plot even "Vector Processed" Sheet with "in Computer" processing, not to mention it was messing up alot of other non-revit programs and the way they plotted.
We switched back to "in printer" processing and and if we have to print a Raster/Color sheet using Raster Processing, then we'll write it to PDF or DWF and print from that.
My question to Autodesk is: Why would this work in version 5 through 8.1 and now when we get to version 9 it no longer works?
Autodesk COULD replicate the failure with the file I sent them, & they have the same plotter as us. Autodesk said they would show the problem to the developers, I hope they fix it in the next version..
Again, is there anyone else that has had this same issue?
(Note:
1. we have 10 seats of Revit licensed through our Network
2. The files I am using and sent to Autodesk have 0 Review Warnings)
