Results 1 to 8 of 8
Thread: Convert to bitonal image
    I could stop if I wanted to LanceMcHatton's Avatar
    2002-04
    Las Vegas, NV, USA
    303
    Default Convert to bitonal image
    Ok, my total time in RD is about 1 hour so far so please excuse what is probably a basic question.
    I'm doing my best to convert raster lines to ACAD lines but it's not working as easily as it did with the sample images. I guess I need to convert my image to a bitonal image but I can't find how to do that. Right now the image has white, black, and red (and probably millions of variations of each since it's a regular scanned image).
    Can someone point me in the right direction or tell me if I'm even on the right path?
    9,804
    Default Re: Convert to bitonal image
    Image | Image Processing | Change Color Depth
    2002-04
    Las Vegas, NV, USA
    303
    Quote Originally Posted by rkmcswain
    Thanks, McSwain!
    Ok, that changed it to just black and white, no in-betweens. But I lost the red and that's the one I needed. I understand there's a way to work with the image to "extract" just one color out of it. Where would that be?
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Quote Originally Posted by LanceMcHatton
    Thanks, McSwain!
    The only thing I can think of would be to make 2 copies of the image with different names. Change one to a bitonal image & put it over the colored image. The bitonal image will be transparent & let you see the colored imge. That will give you the bitonal to snap to & the colored one to use as a guide.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    9,804
    Thanks, McSwain!
    A bitonal image contains 2 colors, black and white. Assuming your background color is black, you will only see the "white" parts of the image. The "white" parts of the image will actually be the color of the layer on which the image resides. Move the image to a red layer, and the visible parts are now red.
    Abilene, TX
    1,181
    I was under the impression that he has 3 colors: black, white, & red. As in a redlined drawing.
    9,804
    Quote Originally Posted by drafter29
    That may be true, but a bitonal image can only display two colors.
    Abilene, TX
    1,181
    That's the reason to overlay the bitonal version on the color version. It gives you the chance to see the difference between the black & red lines.
  1. Raster design bitonal image for contour follower
    By swyman in forum AutoCAD Map 3D - General
    Last Post: 2010-09-01, 03:30 PM
  2. convert to bitonal image
    By rschaff in forum Raster Design - General
    Last Post: 2010-08-03, 02:07 PM
  3. convert image into dwg
    By vergasov in forum ACA General
    Last Post: 2004-07-20, 10:12 PM
  4. convert image into dwg
    By vergasov in forum Revit - In Practice
    Last Post: 2004-07-08, 05:04 AM
