Results 1 to 8 of 8
Thread: Convert multiple Field Objects to Text Objects in one operation
    2003-07
    17
    Question Convert multiple Field Objects to Text Objects in one operation
    Hello all.
    I have an instance where, because we keep our text in a separate drawing from our linework, I need for the field information to be converted back into regular text. Now, I know I can right click and "Convert Field to Text", but I want to know if there is a way to convert multiple fields to text in a single shot. I don't want to go through the above process 100 times if I can avoid it.
    I'm running 2005, BTW.
    Thanks.
    Ron
    2001-03
    13,499
    Default Re: Convert multiple Field Objects to Text Objects in one operation
    Hi
    Maybe...
    Fields and eTransmit ( I am not so sure about this one, would need to carry-out some testing ).
    OR
    If your Fields are made up of MText Objects, you could Explode them into Text Objects - their associated Field properties will disappear.
    OR
    _.DxfOut to R12 format your text Objects with Fields associated to them, then _.DxfIn back in - this process will remove Field properties from text Objects.
    OR
    Have a good one, Mike
    2003-07
    17
    Thanks for your help. I had tried exploding, but we had actually made our fields in DTEXT, so that didn’t work. I had tried doing a “SAVE AS” R12/DFX”, but it still seemed to preserve the fields. I had forgotten about ”DFXOUT”
    So, on a slightly related note. Anyone know a lip routine where you can convert Multiple DTEXTS to MTEXT in one shot but keep the (now former) DEXT separate?
    Thanks again.
    Ron
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by rortiz
    Thanks again.
    Ron
    If you have express tools installed check out TXT2MTXT command.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2003-07
    17
    Thank you for responding. Yes, I'm familar with Txt2Mtxt. But, I need something that would turn 500 different dtext entities into 500 different mtext entities. So far as I know, the above routine doesn't do that. If there is a way to do so, please let me know.
    Thanks!
    Houston
    7,520
    Thanks!
    That function is one of the 700+ tools in ToolPac [ http://www.dotsoft.com/toolpac.htm ]
    2003-07
    17
    Quote Originally Posted by Mike.Perry
    Hi
    Maybe...
    OR
    OR
    OR
    Well, I stumbled across this inadvertently and I thought I'd share - it seems if you FLATTEN dtext with fields in it the fields switch over to regular text. Pretty neat, I thought.
    rkmcswain:
    Thanks for sharing the link. I don't think I can get the money from my bosses without definitely justifying the savings immediately. I'll have to look at the other features as time permits.
    Houston
    7,520
    That is a good tip!
    rkmcswain:
    Justifying the expense was the easy part. The $245/seat is what, about 2 billable hours? We probably save that each week
  1. Convert Field to Text within Block Globally
    By OCD in forum AutoCAD General
    Last Post: 2013-02-08, 02:57 PM
  2. Replies: 1
    Last Post: 2008-11-11, 02:58 PM
  3. Moving Text Objects relative to base point as other Objects are moved / scaled
    By William Troeak in forum Dynamic Blocks - Technical
    Last Post: 2007-02-06, 01:35 PM
  4. Replies: 5
    Last Post: 2006-08-11, 01:32 PM
  5. How to convert AutoCAD Text into drawing objects
    By lidija1 in forum AutoCAD General
    Last Post: 2004-09-11, 03:05 PM
