Results 1 to 9 of 9
Thread: Drawing will not open - Access violation. Unable to open drawing.
    2004-06
    OHIO
    33
    Exclamation Drawing will not open - Access violation. Unable to open drawing.
    I cannot open this drawing and can't xref this drawing into another drawing. When i open it it prompts me as if it is read only but it is not and when I say yes to open it tells me Access violation. unable to open drawing.
    When I xref the drawing it says that it is invalid and function cancelled.
    Has anyone ever seen this and if so how do you solve this? Thanks.
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,257
    Question Re: Drawing will not open - Access violation. Unable to open drawing.
    any chance you can make a screen capture so we can see the exact error code?
    Quote Originally Posted by akasten
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    Houston
    7,519
    Default Re: Drawing will not open - Access violation. Unable to open drawing.
    What drawing? Can you upload it somewhere so someone else can try?
    2004-06
    OHIO
    33
    The error message is attached. The thing is that everyone else can open the drawing and I can't. So is there something wrong with my settings or the drawing?
    2001-12
    St. Louis
    4,257
    with the 'read-only' message... and this error, I'd just have to guess that your permissions are mucked up. I'm assuming you're accessing these drawings from a networked location?
    Technical Editor
    AUGI Addict tedg's Avatar
    2005-06
    in the upper right corner
    2,287
    Talking Re: Drawing will not open - Access violation. Unable to open drawing.
    Just a shot in the dark,
    Check in your Preferences (options) under 'Open and Save', in the External References category in the 'Demand Load Xrefs' area and see if you have"Enabled with copy" checked off. You should if everyone is supposed to be referencing and working on shared drawings and xrefs.
    Also, make sure everyone else in the office does too. It allows everyone to load xrefs when someone else is in it. Also, if someone is just referencing the xref and they don't have "enabled with copy" checked off, it locks everyone else out.
    I hope it helps.
    Ted
    I could stop if I wanted to H.Hunter's Avatar
    2005-08
    Somewhere, but not here
    241
    If you were in our office, I woudl know what the problem is. Chances are something got glitched up. I would check the securities settings on your machine and the file. Although you probably would be having more issues than one file if it was that. The only other recommendation I make is to reboot your computer and see what happens (although I'm sure you've tried that).
    2005-06
    2,287
    Quote Originally Posted by tedg
    I hope it helps.
    Ted
    This happens allot at our office when someone new starts and/or a new seat of AutoCAD is loaded. The default is just "Enabled" which caused the above mentioned problem.
    2004-06
    OHIO
    33
    All of the settings that you suggested are correct: DEMANDLOAD is correct. Xloadctl is correct. We have rebooted numerous times. We have checked his securities and locks and everything is the way it should be. No interferences. I think it is just one of those things that the software coughs up once in awhile. We just bypassed the drawing and replaced it with a recalled drawing from the past. It works now. Just don't know why all of a sudden it wouldn't let him in the drawing or create a xref.
    Thank you all for your great suggestions, just AutoCAD loves playing tricks. LOL.
  1. Unable to Open Drawing
    By dillarm in forum AutoCAD General
    Last Post: 2010-05-27, 02:18 AM
  2. Replies: 8
    Last Post: 2007-08-06, 02:58 PM
  3. Insert Saved View results in - Access Violation. Unable to open drawing.
    By jfields.61630 in forum AutoCAD Sheet Set Manager
    Last Post: 2007-02-22, 08:10 PM
  4. Unable to Open a drawing file
    By mwittens in forum AutoCAD General
    Last Post: 2005-07-07, 08:02 AM
  5. Unable to open a drawing from sheet set
    By jminta in forum AutoCAD Sheet Set Manager
    Last Post: 2005-06-08, 06:47 PM
