Thread: View Names and Elevation Names not the same.
    2003-07
    142
    Default
    During the initial layout phase, it wasn't important to have the different levels identified in the floor plan views. It was a big mistake. I am now trying to to have the plan view plans to match the name of the levels in section and elevation view. When I rename the plan view name it doesn't update the section or the elevation name. When I try to change the section or elevation level name to match the plan view name, a message says the name already exists. Please advice how to update the level names to match the plan view names.
    Thank you in advance
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: View Names and Elevation Names not the same.
    Chances are you have a bunch of duplicated views.
    Go to the view properties of the plan view in question. Near the bottom of the dialog will be a field called associated view. Whatever view shows there is the parent view of your duplicated view. The parent's name will show in the elevation & section level tags.
    Hope this helps...
  1. Revit 2012 can you Delete Unused Room Names & Department Names
    By billy007nh in forum Revit Architecture - General
    Last Post: 2012-12-03, 04:43 PM
  2. Replies: 35
    Last Post: 2009-08-18, 07:52 PM
  3. Help: Convert Space names to Room Names??
    By stykface in forum Revit MEP - General
    Last Post: 2009-06-30, 02:47 PM
  4. Room Names vs. Space Names
    By mattw in forum Revit MEP - General
    Last Post: 2009-03-06, 06:30 PM
  5. Turn off elevation view names in plan?
    By ian.117632 in forum Revit Architecture - General
    Last Post: 2006-07-24, 09:16 PM
