Results 1 to 10 of 14
Thread: RS3 to ADT/ABS 2006
    2006-01
    Milwaukee, Wisconsin
    383
    Default RS3 to ADT/ABS 2006
    Well, here's a problem that I wish I would have thought of when we were still in beta.
    I've got a project starting up and would like to use RS3 instead of RS2. The hitch is that the architect is on ADT2006.
    I can only save to ADT2007 objects in RS3. Has anyone ran into this yet? I wonder how easy it would be to add the ADT2006 export functionality back. I really think this is going to be a big issue.
    Any other comments before I send this off to our friends at the Revit Shop?
    Thanks,
    __________________
    Rick McElvain
    Arnold and O'Sheridan
    2002-09
    Madison, WI
    4,440
    Default Re: RS3 to ADT/ABS 2006
    I'm going to be doing the same thing on a project that we sold as being full revit and ABS. This is huge. I never even thought that Adesk would do something that . So now I guess I have to export to ADT 2007 (which I need to get installed on my machine) and then export to 2006 from there. Oh wait, I can't do that either. In case you haven't heard, that's one on the issues with ADT2007. There's about 8 posts reguarding exporting issues from 2007 to lower versions. This needs to be addressed and fixed. Sooner rather that later.
    Well I just double checked RS2 and it allows you to kick it back to a 2000 format. I' guess I'm a little confused because in RB (current version) you can kick it back to a 2000 format. I haven't done this yet, so I may be missing something.
    When you export to an acad file, what gets created, solids or planes? It'd be nice to have the option to select to export as ADT objects, or ABS object. I can see where this could get real messy real fast.
    Any others have some input on this?
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    2003-04
    Irvine, CA
    6,778
    When I use File > Export > Cad Formats I see the following formats. I believe the format for 2006 is the same as for 2004?
    2002-09
    Madison, WI
    4,440
    Well that makes me feel much better. . I don'thave RS3 loaded yet. Our workstations get rebuilt this weekend so I can't test this. Thanks for the info Steve. I'm guessing that you did this in RS3?
    I believe you are also correct in saying 2004, 2005, and 2006 are all the same format. I'd still like the ability to say "export model only to ADT/ABS object" I haven't tried this function yet, but I will need to do this shortly. Any advice on this type of colaboration between RS3 and ADT/ABS?
    Dave Peterson
    2006-01
    383
    Quote Originally Posted by Steve_Stafford
    When you take it one step further though you'll notice that you don't have the option to select ADT objects .... ACIS Solids or polymesh only.
    In RS2 (and RS3 to 2007) you have the Export as ADT and ABS Objects.
    So, sorry David .... you're back to HUGE PROBLEM ....
    The only option is to use RS2 and ADT2006 or use RS3 and ADT2007 ....
    I still wonder if they can't put a really really really quick fix in RS3 though that would allow us to keep the ADT2006 version.....
    __________________
    Rick McElvain
    2002-09
    Madison, WI
    4,440
    They still need to fix the export from ADT2007 as well.
    Where is this "next step"? As I said I haven't tried this yet.
    Dave Peterson
    2006-01
    383
    David,
    Can ABS2006 import IFC files?
    __________________
    Rick McElvain
    2003-04
    Irvine, CA
    6,778
    Sorry my view was not 3D when I looked...the option is not there as Rick says. Seems like it makes the ABS bundle less effective without eh?
    2006-01
    383
    I put in a Service Request and will update the thread with any news....
    __________________
    Rick McElvain
    2002-09
    Madison, WI
    4,440
    I'm waiting to get my copy of 2007 which I should have monday. I'm not sure. But in RS 2, when you export to IFC, there wasn't much there to export.
    In 2005 you can insert a .sat file, and .dxb file. Also .dxf. I suppose you could convert to max and insert that way. 3ds is also an option. I think the only answer here is to export to solids. From there you can convert the solids in ADT to AEC mass elements., and Mass Elements to walls (I think) But I can't imagine the about of data you just lost by doing it that way.
    All I can say is Dooh.
    This needs to be fixed as in yesterday. 335,000 sqft of building to coordinate, and I'm not doing it on paper. It's a good thing we sold ourselfs down stream on the RS boat. I guess we'll just have to shell out about $4-5 grand and buy a copy of Navis works.
    Can they make this any more difficult?
    Dave Peterson
  1. VIZ 2006 crashes when importing DWG file from AutoCAD 2006
    By fat.mongrel in forum VIZ - General
    Last Post: 2007-03-30, 06:49 AM
  2. Content Highway 2006 - Pre announcement (Due Q1 2006)
    By Marek Brandstatter in forum Revit - R & D Lounge
    Last Post: 2007-01-02, 01:27 PM
  3. Replies: 1
    Last Post: 2006-11-21, 11:40 AM
  4. Replies: 1
    Last Post: 2006-05-14, 03:57 PM
  5. 3D Tutorial For AutoCAD 2006 or ADT 2006 ?
    By omorah in forum ACA General
    Last Post: 2006-01-19, 09:54 PM
