Results 1 to 10 of 17
Thread: Hollow Metal mullion profile?
    2004-06
    Memphis TN area
    6,700
    Default Hollow Metal mullion profile?
    Has anyone ever tried to create a hollow metal mullion profile to use with a storefront wall? Does Revit always trim the curtain panel back to the widest point of the mullion (i.e. can't have any part of the curtain panel overlap in front of part of the mullion profile)?
    AERC, PLLC
    Hernando, Mississippi
    I could stop if I wanted to Haden's Avatar
    2004-02
    St. Louis, Missouri
    290
    Question Re: Hollow Metal mullion profile?
    I have just discovered the same problem. I am hoping someone can help me with the way my mullion or profile is defined, so that the ends of the mullions can overlap enough to allow the proper 3d connection. (See attachment)
    Haden D. Smith, AIA
    St. Louis, MO
    2004-06
    Memphis TN area
    6,700
    Default Re: Hollow Metal mullion profile?
    heh that was an OLD thread.... apparently it's not possible. We create HM windows as a window family. It's better that way, anyway, for scheduling and showing them in legend views.
    AERC, PLLC
    2004-02
    St. Louis, Missouri
    290
    Exclamation Re: Hollow Metal mullion profile?
    Quote Originally Posted by patricks View Post
    I would agree that scheduling HM borrow lites and windows is better as windows, but when you have borrow lites that wrap around a corner, it becomes much handier if you can just copy and move gridlines back and forth, rather than having to create a separate family for each combination of lites and mullions.
    Is there anyone else out there who would agree with me that it would be worthwile for the factory to get around to improving this behavior? I can also imagine cases where you are dealing with actual aluminum curtainwall systems with various mullion profiles that might need this kind of cleanup.
    Haden D. Smith, AIA
    St. Louis, MO
    2004-06
    Memphis TN area
    6,700
    OLD THREAD ALERT!!
    I'm once again looking into trying to make Revit curtain wall mullions and panels look like actual hollow metal door and window frame assemblies.
    I understand that I could create custom glass panels with extensions past the normal reference places so that the glass will correctly overlap the "rabbet" portion of the frame. But what about where the mullions intersect? Is there any way to get that to look correct?
    Also, would I need to create separate profiles for the left/right and top/bottom mullions to get the rabbet on the correct side, and then a 3rd profile for any interior mullions with rabbets on both sides?
    AERC, PLLC
    2004-01
    Columbus OH
    463
    [quote=Also, would I need to create separate profiles for the left/right and top/bottom mullions to get the rabbet on the correct side, and then a 3rd profile for any interior mullions with rabbets on both sides?[/quote]
    Yes, each mullion condition would be a seperate profile. The head, sill, and intermediate are pretty easy to keep track of but the left and right are a constant headache for us. Each user seems to understand the idea of left or right but nobody seems to agree on whether its when you are looking at the curtain wall from the interior or exterior. Not to mention when people don't pay attention to interior/exterior face of the curtain wall when its being drawn.
    2007-03
    Salt Lake City
    360
    Quote Originally Posted by eric.piotrowicz View Post
    Maybe you can enlighten me as to how you can tell what is interior and exterior when creating a curtain wall. ( I know this issue also affects the model when you export out to gbxml as well).
    Since curtain walls don't have an option like regular wall for what face you're drawing from, I find it hard to tell which direction the curtain wall is facing. Recently I made a custom panel, and from the curtain wall panel family template it's shows you what it considers exterior. so when you place that panel in the family, you can tell which direction the wall is facing. But with a regular glass panel that is centered on the curtain wall line, it's extremely non-intuitive to decipher what direction the curtain wall is facing.
    2009-06
    89
    The flip controls are what give this away. They should always show on the exterior side of a wall in plan, both curtain and regular. Double check that your structure is created correctly and defines the exterior skin accordingly.
    David Moody
    LEED AP
    Autodesk Revit Certified Professional
    Soon to be Registered Architect
    BIM Coordinator/Revit Implementation Specialist
    The Revit Life
    2004-06
    Memphis TN area
    6,700
    Quote Originally Posted by t1.shep View Post
    Maybe you can enlighten me as to how you can tell what in interior and exterior when creating a curtain wall. ( I know this issue also affects the model when you export out to gbxml as well).
    A trick to remember: ALL walls are drawn with the exterior side on the outside when drawing in a loop in a clockwise direction. So if you're drawing left-to-right, exterior will be up side. From top-to-bottom, exterior is right side. So on and so forth. I would also guess that a curtain wall's mullion settings consider Border 1 as the end drawn first and Border 2 as the end drawn second.
    But then the spacebar will flip a wall's orientation while you're drawing it, so there's really no way to tell which end is which if you're having to go back and change stuff after-the-fact.
    AERC, PLLC
    2004-01
    Columbus OH
    463
    Looks like everybody got it answered above. Just to add an extra level of certainty about interior/exterior, I add a left or right curtain wall jamb mullion after placing the curtainwall to verify that its behaving as I expect.
  1. Hollow metal frame with 3 doors
    By jseaman8 in forum Revit Architecture - Families
    Last Post: 2009-08-25, 09:08 PM
  2. Architectural - Hollow Metal Frame
    By Rick Moore in forum Dynamic Blocks - Sharing
    Last Post: 2007-03-09, 05:37 PM
  3. Hollow Metal Window
    By boofredlay in forum Revit Architecture - Families
    Last Post: 2006-09-25, 05:33 PM
  4. Hollow Metal Door Frame?
    By Colquhoun in forum Revit Architecture - General
    Last Post: 2004-04-13, 01:19 PM
  5. Hollow Metal Doors and Frames
    By cgrover in forum Revit Architecture - Families
    Last Post: 2003-09-10, 02:04 PM
