Thread: Fillet command is it Tangential?
    All AUGI, all the time Statler's Avatar
    2002-01
    At right angles to reality
    516
    Default Fillet command is it Tangential?
    Hi.
    I'm working on some road alignments and need to be accurate so just checking.
    When using the fillet command does it alway return the same result as Circle and TTR?
    I dont know how its programmed to produce the end result.
    Many Thanks
    Richard
    I could stop if I wanted to andy.manninen's Avatar
    2005-12
    @ _ork
    304
    Default Re: Fillet command is it Tangential?
    Quote Originally Posted by McDonaldRi
    Hi.
    Many Thanks
    Richard
    I have never had bad results from the FILLET command. Always tangental, thats what its for. The only problem would be clicking the lines in the wrong spots. Whoops! UNDO!
    :Cheers:
    Andrew Manninen
    CAD Manager
    The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
    2005-10
    80
    Hi.
    Many Thanks
    Richard
    my experience is that fillet works far better than circle and ttr because normally for me the ttr does not produce line endpoints that line up correctly. When using the fillet command the lines are actually joined as plines..
    Houston
    7,543
    Whichever way you choose, make these edits while the geometry is near 0,0 - not way out in state plane coordinates (or any large coordinate system where the X or Y is in the millions of units)
    2002-01
    516
    Many thanks for the info. I couldn't see how fillet could work without being tangential but thought I'd better check.
    Regards
    Richard
  1. Plines and the fillet command.
    By bskripac in forum AutoCAD General
    Last Post: 2012-04-20, 03:11 PM
  2. Fillet Command Sticky
    By darthyoga in forum AutoCAD Mechanical - General
    Last Post: 2009-01-27, 06:01 PM
  3. Reverse Curves with tangential piece (can we remove tangential piece)
    By dkuhn in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-06-11, 11:11 AM
  4. Where is the fillet command?
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-01-14, 06:21 AM
