I'm trying to upgrade several users' machines from ADT 2005 to ADT 2006. Each attempt to load ADT 2006 fails, with the following message logged:
[5/1/2006 16:32:06] === Installation started on CAD002 by Administrator ===
[5/1/2006 16:32:09] [Info] Windows Installer upgrade is not required
[5/1/2006 16:32:09] System Version = 3.1.4000.2435
[5/1/2006 16:32:09] Installation skipped: MSI Runtime 3.0
[5/1/2006 16:32:09] [Info] .NET Framework Runtime upgrade is not required
[5/1/2006 16:32:09] System Version = 2.0.50727.42
[5/1/2006 16:32:09] Installation skipped: .NET Framework Runtime 1.1
[5/1/2006 16:32:09] Installation skipped: .NET Framework Runtime 1.1 SP1
[5/1/2006 16:32:09] [Info] MDAC upgrade is not required
[5/1/2006 16:32:09] System Version = 2.81.1117.0
[5/1/2006 16:32:09] Installation skipped: MDAC 2.7
[5/1/2006 16:32:09] Installation started: Autodesk DWF Viewer
[5/1/2006 16:32:09] Command = "support\aev\DwfViewerSetup.exe" /u2 /q2
[5/1/2006 16:32:15] [Error: 11] An attempt was made to load a program with an incorrect format.
[5/1/2006 16:32:15] Installation failed: Autodesk DWF Viewer
[5/1/2006 16:32:15] [Info] Failure is ignored
[5/1/2006 16:32:15] Installation started: Flash
[5/1/2006 16:32:15] Command = "support\flash\Silent Install Flash Player 7 AX.exe" /q
[5/1/2006 16:32:15] [Error: 1] Incorrect function.
[5/1/2006 16:32:15] Installation failed: Flash
[5/1/2006 16:32:15] Installation started: Autodesk Architectural Desktop 2006
[5/1/2006 16:32:15] Command = msiexec /i "adt.msi" /L*v C:\DOCUME~1\ADMINI~1.GOS\LOCALS~1\Temp\adtInstall.log
[5/1/2006 16:32:15] [Error: -1073741819] (null)[5/1/2006 16:32:15] Installation failed: Autodesk Architectural Desktop 2006
[5/1/2006 16:32:15] Installation aborted
[5/1/2006 16:32:25] === Installation ended ===
Each user is on a recently deployed HP xw4300 workstation, 3 GHz clock, 2GB RAM, Quadro FX1400 video card. ADT 2005 loaded without problems on these machines.
2006 was loaded successfully on several other machines with existing seats of 2005 - just these HP's are problematic.
