Results 1 to 8 of 8
Thread: Drawings with Irregular Viewports in, Plotted to PDF, causes problems
    2004-12
    10
    Exclamation Drawings with Irregular Viewports in, Plotted to PDF, causes problems
    My office has been running into a Big Problem. We have Consultants that do not use AutoCAD so we need to create PDF�s for them. So once we create the PDF only half of the sheet is created. I have come to the conclusion thru trial and error that the irregular shaped viewports is the problem. I have searched and searched for a solution but have yet to find one. We have multiple files with this problem(Irregular viewport).
    2005-07
    2,354
    Default Re: Drawings with Irregular Viewports in, Plotted to PDF, causes problems
    Quote Originally Posted by Kiduno99
    What PDF program are you using? Or is it the built into the 2007 series?
    I have been using a program called PDF Factory for the last 2 or 3 years and have had no problems whether using rectangular or irregular pline viewports.
    2004-12
    10
    Exclamation Re: Drawings with Irregular Viewports in, Plotted to PDF, causes problems
    2004-12
    10
    I am using Adobe Acrobat Professional 6.0 I am plotting it using AutoCAD 2005, to create the PDF.
    2005-07
    2,354
    Do you have all the current service packs/updates for both Acad and windows (not sure if this matters though).
    When was Adobe prof 6.0 released? It may simply be the case that it isn't supported under Acad 2005.
    Houston
    7,520
    Non-rectangular viewports create much larger output files. As do other factors, see http://support.autodesk.com/Getdoc.asp?ID=TS31465
    Have you tried plotting to DWF?
    2001-03
    13,499
    Hi
    Take a look at this thread ( Creating PDFs with Polygonal Viewports ).
    Plus, give the forum search facility a try, if you have not already.
    Have a good one, Mike
    100 Club The VLG's Avatar
    2005-04
    on the up....
    137
    We had a slightly similar problem, is your VP on a frozen layer? if it is unfreeze it & just set it not to plot if you don't waht it shown. I know that this was a solution to our problem.
    verisimilitude is a life choice...probably...
    Cheese...don't believe the hype.
  1. PLOTTED DRAWINGS TURNED ON SHEET
    By rjackson88 in forum AutoCAD Plotting
    Last Post: 2010-07-08, 06:19 PM
  2. Text not showing up in irregular shaped viewports
    By steve922542 in forum AutoCAD General
    Last Post: 2007-11-19, 04:23 PM
  3. Mechanical 2008 - Embedded watermark appears in plotted drawings
    By Pete. in forum AutoCAD Mechanical - General
    Last Post: 2007-07-13, 10:53 AM
  4. Plotting issues with PDF - Irregular Shaped Viewports
    By sgull in forum AutoCAD Plotting
    Last Post: 2006-05-02, 07:20 PM
