Thread: Layout import with Design Center - Corrupted
    2015-11
    Jo'burg SA
    4,512
    Default Layout import with Design Center - Corrupted
    OK here's a thing I've not found before. I've got a template setup (per Layout) with part of it as a block and the rest as a xref. The block contains only the attributes, while the xref contains the title's linework, logos & text pertinent to the project. All 3 (xref, block & template) is set with INSUNITS=4 (for millimeters).
    Now I start a new drawing from the ACADISO.DWT file: i.e. its INSUNITS=4 as well. If I use Design Center to import one of the layouts from the template the XRef is scaled down and the block is scaled up.Neither are the correct size. If I use the Page Setup Manager's Import facility it imports correctly (and of course a save as works fine as well) but not the DC method.
    Is there something strange with DC? I'm in Vanilla 2008.
    2008-03
    383
    Default Re: Layout import with Design Center - Corrupted
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by archie.manza View Post
    Thanks, but unfortunately that's not it. As I've said, the INSUNITS are all set to millimeters throughout, even those defaults in Options (which shouldn't apply since the INSUNITS are never set to 0 - Undefined). Also this happens on any PC, not just one.
    This error ONLY happens when using DC. If I make a block of the TB and WBlock it out, then insert into a new drawing on a new layout the scale of all are still correct. Just can't figure out what's happening.
    I've now simply told everyone here not to use DC for importing Layouts until I can figure out what's wrong.
  1. 2012: Can't import Dimstyle through Design Center
    By tplancon in forum AutoCAD General
    Last Post: 2012-04-24, 03:53 PM
  2. Import Scales through Design Center
    Last Post: 2009-07-06, 03:25 PM
  3. Inserting a layout using Design Center
    By lpl in forum AutoCAD General
    Last Post: 2009-06-11, 08:50 PM
  4. Design Center Problem - Inserting to Layout Tabs
    By burchd in forum ACA General
    Last Post: 2008-03-12, 10:47 PM
  5. Stair Railing Panels always layout from center
    By Andre Baros in forum Revit Architecture - General
    Last Post: 2006-08-21, 07:40 PM
