Thread: Thoughts on ABS
    100 Club finney13's Avatar
    2005-03
    Brentwood, TN
    134
    Default Thoughts on ABS
    I currently have ABS 2006 and am about to upgrade to 2007.
    The company I work for is a smaller (10 employees) MEP firm. Everyone is on base AutoCAD except for me. I was able to convince the owners to try one version of ABS so we could see if it would be a benefit.
    I have been able to play with it a decent amount, but cannot convince the owners to allow me to attend an ABS training course, Autodesk University, or the like. I am trying to teach myself at this point and am getting the hang of things.
    Basically, I am figuring that as with all AutoCAD, the hardest part is getting the company standards set. Once this is done, I believe things should move along much faster.
    I finally have a computer at the house that has the ability to run ABS, and am thinking of installing it at home under the trial version and working on tutorials and learning more there(seeing as there is never really time to spend on it at the office).
    Have most people on here running ABS taken a course to learn it, or did you have to teach yourself? Also how hard has it been to get your company to implement ABS for the rest of the users?
    Thanks
    2003-10
    San Francisco CA
    1,190
    Default Re: Thoughts on ABS
    It took me two years to convince management to buy two versions of ABS for my department. Now after a year of using it I think I have management convinced to buy two more seats.
    As for taking classes, I've attended a couple of dog and pony shows but no actual classes. I have considered attending an actual class but don't think it would be useful since we use ABS a little different than most users. (I work for a large electrical contractor and we use ABS to draw out our conduit and cable tray routing and coordinate this routing with the other MEP trades.) From my standpoint, the ability to quickly and easily create sections and cuts greatly increases my productivity over traditional 2D drafting.
    I agree with your assessment that the creation of standards and getting the drawing setup the way that you want is the greatest time factor of ABS.
    Hope this helps.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2005-03
    Brentwood, TN
    134
    The ability to cut sections like that really is helpful.
    Good luck on getting more seats.
    2002-09
    Madison, WI
    4,439
    Before you impliment, be sure to make sure that you can still save back to 2006 format. I've heard several complaints when it comes to exporting back to 2004 format. One huge feature (or at least I think so) in 2007 is the ability to do out right walk-thrus. Stand on the floor, look up, and press the forward key. I think it's a great tool to run visual checks.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. My thoughts on BIM
    By bbeck in forum BIM Management - General
    Last Post: 2010-06-04, 03:40 PM
  2. What are your thoughts?
    By jcoe in forum Revit Architecture - Families
    Last Post: 2005-04-19, 04:52 AM
  3. What are your thoughts?
    By jcoe in forum Revit Architecture - General
    Last Post: 2005-04-18, 02:38 PM
  4. Some thoughts.
    By dpasa in forum Revit Architecture - General
    Last Post: 2004-09-24, 10:31 AM
