Results 1 to 7 of 7
Thread: A little Bug I think - I have to type VLIDE and not VLISP to get Visual Lisp Editor
    I could stop if I wanted to CadDog's Avatar
    2005-06
    So Ca
    439
    Default A little Bug I think - I have to type VLIDE and not VLISP to get Visual Lisp Editor
    Hi everyone...
    I found this on my AutoCAD 2006...
    I don't know if it is just my station
    because I'm the only using it right now
    but here is what I found...
    I need to type VLIDE and not VLISP to ge my Visual Lisp Editor...
    Just like VBAIDE I guess...
    Is it just me...???
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: A little Bug I think - I have to type VLIDE and not VLISP to get Visual Lisp Editor
    Quote Originally Posted by CadDog
    Hi everyone...
    Is it just me...???
    No, try to type VLIDE in 2002 also, and see what happens
    : ) Happy Computing !
    kennet
    Earth
    9,805
    Hi everyone...
    Is it just me...???
    I always thought VLISP was an alias or shortcut and that VLIDE is the core command.
    I have always used VLIDE
    R.K. McSwain | CAD Panacea |
    I could stop if I wanted to lmitsou's Avatar
    2003-01
    UK
    219
    Lightbulb Re: A little Bug I think - I have to type VLIDE and not VLISP to get Visual Lisp Editor
    VLIDE or VLISP, they both work fine (tried it in AutoCAD 2005, 2006 and 2007) with the same result.
    Earth
    9,805
    Quote Originally Posted by lmitsou
    That's only because of this function...
    (defun c:vlisp ()
      (if (/= nil c:vlide) (c:vlide))
    ...defined in the stock "acad200Xdoc.lsp" file.
    If this file is altered, deleted, not in the support path, etc. then only VLIDE (the core command) will work.
    2005-06
    So Ca
    439
    Quote Originally Posted by rkmcswain
    (defun c:vlisp ()
    Thanks R.K. McSwain...
    I did a search using Vlisp in AutoCAD 2002, 2005, and 2006
    I didn't find that defun anywhere...
    No big thing now that I understand the problem...
    I will just add that defun to my acaddoc.lsp
    Thanks and sorry I didn't back sooner...
    Earth
    9,805
    That defun should be in your acad200Xdoc.lsp - if it's not, then that file has been modified or it's missing - either way may result in more errors....
    Rather than add to "Acaddoc.lsp", I would try and find the original stock acad200Xdoc.lsp file and restore it to it's home.
    Good luck.
  1. CP222-1L: The Visual LISP Editor: It's Not Just Another Notepad
    Last Post: 2014-12-01, 02:06 AM
  2. CP218-2L: Easing Into the Visual LISP Editor
    Last Post: 2014-12-01, 01:51 AM
  3. CP215-1L: The Visual LISP® Editor: It's Not Just Another Notepad
    Last Post: 2013-05-05, 01:31 PM
  4. visual lisp editor should be like visual studio
    Last Post: 2011-11-17, 05:33 PM
  5. LISP Editor Vlide to support unicode
    By dmarcotte4 in forum API Wish List
    Last Post: 2010-09-28, 12:59 PM
