Results 1 to 10 of 12
Thread: 3d trees
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    Default 3d trees
    My elevations in hidden line generally look dead because the Revit trees look dead. How do you folks get trees to look decent? I need something I can place in front of a house or behind it . Detail components will only appear in the foreground. I would rather not re-invent the wheel so any tips would be appreciated.
    Joe
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: 3d trees
    Hi Joe,
    Do R 9's new controls for images fit the bill? You can import a jpeg of your real tree into your elevation and make it foreground/background or layer it with other images
    Edit: Not so good Joe. The issue is jpeg's come in with a background that can't be transparent so unless all your trees are rectangular this probably won't do the trick
    2015-12
    3,753
    Joe,
    I tried taking a Sketchup tree and exporting it to 3D dwg. Import into Revit and it displays OK (see image and notice it allows Revit objects to poke through the 3D face). I imagine this would work for any 3D face type of Autocad object
    2003-12
    Victoria, BC
    1,273
    Thanks Dimitri,
    I tried taking a Sketchup tree directly into a mass and then into Revit but the mass barfed up the Sketchup file. Said I should simplify it. I'll try your tip.
    Joe
    All AUGI, all the time DanielleAnderson's Avatar
    2004-06
    Mostly in Mom-land
    704
    Joef,
    I'm not sure how fancy of a tree you are looking for but this is one idea...an idea from Jeffrey McGrew...
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    i use dwg blocks inserted in both elevation views of a plant family, set the visibility to be only on in each elev view and both on in 3d and it looks great. since they r dwgs they will scale automatically w the tree size.
    Scott D. Brown, AIA
    BECK
    2003-12
    Victoria, BC
    1,273
    Thanks for all the tips. I've been playing around with autocad trees stuck into plant families and it seems to be the solution. Thanks all.
    Joe
    2003-05
    East Walpole, MA
    893
    That's good, Scott.
    I tried gross-modelling something in a Plant Family, but, of course, you can't free the model lines from their reference planes, so you can't do an elevation and then copy-rotate.
    Then tried doing that in a Project. The copy-rotate worked, but couldn't move or copy the darn things because model lines are stuck to their reference planes.
    (I was hoping for a pure Revit solution - no luck).
    So, I suppose you could use that ACAD Block setup, along with your own Grouped 2D Detail lines for PlanView embellishment if you wished.
    Where'd you get the tree blocks, if you don't mind me asking?
    Geof
    Português - Revit Moderator fernando's Avatar
    2003-11
    Leiria - Portugal
    325
    my usual tree , for that problem
    2003-05
    Coast to Coast
    4,440
    Narlee, make sure you import the dwgs into a base plant family, then nest that into the final plant family, this will let it scale like the one I posted. as to where I got the blocks I have no idea, I did this in release 2.0 of revit, so I think it came with softdesk v8 or we just had them allready. Just do a search for .dwg blocks and you will find tons of them.
    Scott D. Brown, AIA
    BECK
  1. Trees
    By GS Fulton in forum Revit - Rendering
    Last Post: 2009-01-27, 01:13 AM
  2. Trees
    By m_r_meza in forum Revit Architecture - General
    Last Post: 2007-10-22, 11:57 PM
  3. 2d Trees
    By dsw98 in forum Revit Architecture - General
    Last Post: 2007-07-20, 12:46 PM
  4. 3d trees
    By john84851 in forum Revit - Rendering
    Last Post: 2005-05-09, 09:07 PM
