Results 1 to 9 of 9
Thread: Revit/Quickbooks Interference
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Default Revit/Quickbooks Interference
    Well for nearly a year i've grinned and bared this issue. Usually it's occurred on a pc that was due for a reformat anyway so i've just used this issue as an excuse and rebuilt pc's when they have this issue.
    For those of you not familiar with the issue
    I've got a really strange problem, since I installed this build of Revit over the holidays, now when I start "Quickbooks Timer" the Revit installer starts. If I then cancel the install twice, the quickbooks timer starts.
    I suspect a registry error but I'm not sure what?
    Any clues or suggestions on how I can fix this, I've tried reinstalling the quickbooks timer which went fine but the revit installer still starts when I try to start the timer.
    originally posted by Kim.
    Now i've had it occur on a brand new pc, which i certainly don't plan on rebuilding.
    All programs are always installed under the domain administrator login.
    Uninstalling/Re-installing of both programs does not resolve the issue, and the issue does seem to be somewhat random in when it occurs, but it is definitely consistent throughout our office. It has occurred on 6 computers since i've been here.
    Letting the installer run will cause revit's licence to become corrupt and have to be installed.
    I've filed this with Autodesk Support but the Asia Pacific support department still seems to be down or something?
    Does anyone have a solution to this issue?
    Thanks.
    PS. We are using Quickbooks Timer 2003.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,729
    Default Re: Revit/Quickbooks Interference
    I use Quickbooks Lite 2004 at home, and can't say I've had any problems. But, maybe I'm just lucky.
    I once had the Microsoft Windows Install Cleanup Utility recommended to me for an installation problem I was having, maybe it might help your problem, even thought it doesn't sound like it directly an install issue? By the sounds of things, it might be worth a look.
    2005-05
    TX
    447
    I have been having this problem with Acad 2007/Revit 9. Sometimes I can be in a program, click on a command and the installer for Acad will pop up looking for acadfeui. It was looking for it in the temp directory under local settings, so Friday, I went into the temp directory and erased everything. I will see if I am still having this problem this week or not.
    I could stop if I wanted to Damo's Avatar
    2004-04
    London, UK
    320
    Chris,
    I've been using both Revit (from 6.0 to 9.0) and QuickBooks (QuickBooks Pro 2003 & 2005) on the same PC for a few years without any problems with either.
    The only variations I would note with your post are: (1) I'm using the full programme, not the timer only function, and (2), it's the UK version of QuickBooks.
    HTH
    Damian
    I know it can be done, I just don't know how to do it yet
    All AUGI, all the time tc3dcad's Avatar
    2003-10
    Charleston, SC
    575
    We use Quicken Premier SB and have had no problems to speak of yet.
    Thomas - Palmetto State Custom CAD, LLC
    Custom Residential, Historic Renovation, As-Builts, Landscape & Irrigation, 3D Visualization, etc.
    Semper Fi
    2004-05
    Brisbane
    1,115
    I've tried this and unfortunately doesn't resolve the issue.
    I'm pretty sure its specific to the timer...
    It also appears to be something to do with the order in which the programs are installed. Main problem is that once the problem starts I don't know how to get rid of it. I've finally received a reply from Autodesk regarding by support request too, which is a good sign.
    Quote Originally Posted by Autodesk
    Thank you for choosing Autodesk Subscription. Your Support Request has been escalated to the Autodesk Support Operations team for resolution. We will notify you immediately by email whenever your Support Request is updated. We appreciate your patience as we work to resolve your inquiry.
    Lets hope they have some insight.
    Thanks again.
    Chris Price
    Xrev Pty Ltd
    Revit Rants BLOG
    2004-05
    Brisbane
    1,115
    I have recently spoken with Autodesk support and they have advise:
    As spoken via our telecommunication, I seek to once again extend our apology for the inconvenience caused by the conflict/incompatibility between Revit and Quickbooks.
    The situation that you have described is a known one, and we have since lodged this Change Request with our developers for rectification. I wish ensure you, that your concerns are valid, and of great importance to Autodesk.
    I have been informed by our Development team that this issue would be attended to in the future releases of Revit, and that we will monitor its outcome closely. Should there be a new build that would address this issue, We will keep you notified as soon as possible via email.
    Hopefully it will make it into the next release of Revit; til then will just have to advise people to hit the cancel button twice and if they forget occassionally re-install revit...
    I hope someone finds this information useful.
    Chris Price
    Xrev Pty Ltd
    Revit Rants BLOG
    2003-08
    4
    I am having something of a problem as well.
    I am trying to run the full QB Premier and the new Timer. When I initiate the timer I get an error message that all resources are used up and to close some programs, when nothing is running.
    I hope ADesk can get this resolved on the next build. I am contacting QB as well.
    Regards,
    2005-05
    TX
    447
    Actually, I am still having the problem, but it is with Intuit Master Builder accounting program, so, it is not limited to QB. I get into the program without a problem, but as soon as I click on a module link, it appears.
  1. Interference Check
    By ben374582 in forum Revit MEP - General
    Last Post: 2011-05-17, 12:02 AM
  2. SAP For Revit 2011 - UI Interference?
    By james.austin in forum Revit Architecture - General
    Last Post: 2010-10-29, 09:07 PM
  3. Revit Interference Check vs Navis
    By jamesgchambers in forum Revit Architecture - General
    Last Post: 2010-02-24, 12:52 PM
  4. Rebar interference
    By asaastad in forum Revit Structure - General
    Last Post: 2008-07-30, 03:25 PM
