Thread: Different fonts have started showing up as default AutoCAD fonts
    2006-05
    2
    Unhappy Different fonts have started showing up as default AutoCAD fonts
    Having problems with fonts. Using Architext without problems, however suddenly fonts started showing up as defalt autocad fonts. Once I restart the program, fonts show up correctly until I open another file or two in which all open files start showing up (and printing) in defalt font. Already tried auditing and purging files to no avail. The problem seems to be getting worse, any suggestions?
    13,656
    Default Re: Different fonts have started showing up as default AutoCAD fonts
    Hi
    Look into...
    FontAlt
    FontMap
    Plus, could you please explain your particular situation a little more... more details, more information...
    Have a good one, Mike
    2006-05
    2
    Problem solved! Thanks!!!
    13,656
    Thumbs up Re: Different fonts have started showing up as default AutoCAD fonts
    Quote Originally Posted by jackie.112886
    Hi
    Could you please take the time to post the solution to your particular issue / problem, so others may benefit from such information, in the future...
    Mike
  1. default fonts in schedules
    By gravelin in forum Revit Architecture - General
    Last Post: 2015-11-20, 05:02 PM
  2. 2011: Fonts Not Showing in Text Style Box
    By khworley in forum AutoCAD General
    Last Post: 2013-01-11, 11:47 AM
  3. 8.1 and New Fonts/Importing Fonts
    By briandiercks in forum Revit Architecture - General
    Last Post: 2007-03-05, 11:23 PM
  4. DWF loses protected fonts - download fonts option?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2006-03-25, 12:01 AM
  5. shx fonts to true type fonts
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-03-31, 02:53 PM
