Can you set a phase for an opening in a host or for a shaft?
Doesn't seem so.
What I do is create a separate infill, that can be geometry-joined with the "host", if you will. Then I give that infill it's own phase definition.
Geof.
If you create an opening in a wall as a door family type then you can phase it. As for holes in floors or 'openings', don't think so.
Thanks guys
I have found with the shaft tool that if you try to put an existing part of the floor in a previous phase it cuts it even though the shaft was made in a later phase. So you put this infill bit in say the existing phase -representing the part that gets demolished in a later phase- but the shaft tool cuts it out when the phase is set to "existing" as well as when set to "new construction".
So, you're getting the shaft?...tool..
This sounds like one of those "Revit shortcut-automatic thingys" I try to stay away from and do it the old-fashioned way, i.e. forget the shaft-tool thing and shape each floor with a hole in it (& infill as described above). The problem I sometimes find with these "Revit shortcut-automatic thingys" is they're good but not good for all situations.
Just a thought, can you use the linework tool and set the shaft edges to invisible in the earlier phase? Not sure if you're showing floor material or not (assuming you're not).
