I am creating standards for our casework to take advantage to REVIT. The way i want to set up the tag is C45 where is denotes the type (base, wall, etc) the 4 denotes the width (ie 4 = 400mm) and 5 is the elevation. if that being said i want to know the best method for creating the tag and the millwork.
I dont know enough about the tags to start off so i want to try to explain what i want to do with the casework family. If i create the family where the elevation (5 part of the tag) is always constant and the type is always constant (base cabinet) will i be able to create the varying heights and width all in the same family and have the tag read it properly?
So the family would always be a 5 elevation, and the type would always be a base cabinet (for example), but could i get the tag to show a 4 when it is 400mm and 5 if it where 500mm and 6 if it where 600mm etc?
I imagine that i would need some formulas, but i am curious if it will actually work. also would i need a project parameter to get the type and elevation to read the tag, or is this a shared parameter? What is the real difference between shared and project parameters, and when do you use each?
Thanks
Justin
