Thread: Plot 2 No Copies. 1st Plot is ok! 2nd Plot moves on the paper.
    2006-04
    4
    Default Plot 2 No Copies. 1st Plot is ok! 2nd Plot moves on the paper.
    Good morning to all.
    I have a problem with Autocad LT 2006 italian version during a plotting phase.
    When I need to plot n.2 copies of a drawing I set in a proper window "Number of copies: 2"
    In the plotter (HP DesignJet 1055M) the first copy of my drawing is correct, but the second is incorrect.
    For example:
    My drawing is 841x594 mm and I use a sheet 1500x910 mm (my plotter is set with n.2 options: print only inked area and automatic cutting).
    The first copy is printed correct but the second is moved to right of about 659 mm (1500-841) and the drawing is incomplete (cutted).
    Why the 2 options of my plotter are applied only in the first copy?
    Is there a solution ?
    Is a common problem ?
    Is an error made by me or not?
    Is a bug of Hp's drivers?
    Thank you in advance
    Luke
    100 Club Olaf.Banckaert's Avatar
    2006-02
    Belgium
    133
    Default Re: Plot 2 No Copies. 1st Plot is ok! 2nd Plot moves on the paper.
    Hy,
    When we moved to ACAD 2006 ADT, I had to install the new drivers and upgrade the firmware of our plotters (1050c plus & 5500ps). We didn't had that problem like you (not possible to install the Inked Area and slow network).
    Other Q, is auto nesting on? and set to witch time frame?
  1. Plot and Publish log files do not show number of copies
    By sacha.monnom in forum AutoCAD General
    Last Post: 2010-01-20, 05:15 PM
  2. Unable to plot multiple copies
    By pjguerin.161948 in forum AutoCAD Plotting
    Last Post: 2008-08-20, 12:59 AM
  3. Plot and Publish log files do not show number of copies
    By dfarris75 in forum AutoCAD Plotting
    Last Post: 2006-07-11, 03:28 PM
  4. We can’t get AutoCAD 2006 to plot multiple copies.
    By cconfer in forum AutoCAD Plotting
    Last Post: 2006-04-23, 07:49 PM
  5. Multiple misplaced copies of objects in final plot
    By de-co1 in forum AutoCAD Plotting
    Last Post: 2006-01-18, 09:24 AM
