Thread: AutoCAD, to GIF or not to GIF
    13,499
    Question AutoCAD, to GIF or not to GIF
    Hi
    Regarding the following thread within the Autodesk Discussion Groups -
    http://discussion.autodesk.com/threa...hreadID=333860
    The other day we experienced/noticed a very similar problem, some CAD PC's when working within AutoCAD allow the attachment of GIF's via the Image command, some don't....
    The following Technical Documents/Article indicate that AutoCAD supports the functionality of attaching GIF images -
    ID: TS20202 - Supported raster file formats
    ID: TS69570 - Comparison of raster images in AutoCAD® Release 14 and later releases to AutoCAD Release 13
    ID: TS24375 - Favorites folder in DesignCenter
    The World of Raster
    The following Article indicates that AutoCAD does *not* support the functionality of attaching GIF images -
    All about Images
    Confused? I am <:)
    We found that a CAD PC with just vanilla AutoCAD installed does *not* allow GIF images to be attached.
    We have since found that if we install LDT on the CAD PC that contained vanilla AutoCAD (ie 2 Autodesk products installed side-by-side) the functionality of attaching GIF images within AutoCAD becomes available (makes sense as AutoCAD is at the core of LDT). Therefore it seems LDT installs/switches_on something that enables the attaching of GIF images.
    Am I correct with the above or should vanilla AutoCAD have the functionality of attaching GIF images (as stated on the Autodesk web site).
    Thanks, Mike
    13,499
    Thumbs up Re: AutoCAD, to GIF or not to GIF
    Quote Originally Posted by Mike.Perry
    Hi
    The above discussion has progressed further, it now offers a possible solution.
    I've tried the suggestion "IEGIFRD80.DLL"
    So far so good
    Cheers, Mike
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Default Re: AutoCAD, to GIF or not to GIF
    AutoCAD 2005 supports GIF out-of-the-box.
    Forum Manager, Administrator Ed Jobe's Avatar
    4,791
    True Robert, but there is a "bug" of sorts. See the thread Mike referred to in his first post.
  1. Replies: 15
    Last Post: 2010-09-23, 01:57 PM
  2. Replies: 6
    Last Post: 2009-06-01, 07:10 AM
  3. Replies: 3
    Last Post: 2007-09-07, 04:36 PM
  4. Replies: 2
    Last Post: 2007-03-30, 11:28 PM
  5. Replies: 21
    Last Post: 2006-12-16, 04:44 PM
