Thread: Reference Plane - Delete
    I could stop if I wanted to raddis's Avatar
    2015-12
    208
    Default Reference Plane - Delete
    I give up! I give up! I give up!!!
    Ok, I'm sure I'm doing this completely wrong, but I'm trying to self teach myself Family Creation and Editing. I'm taking the Fixed window family and editing it to create a more "generic" look.
    I have most of it working. However, there is this "not a reference" reference plane at the bottom of the Exterior/Interior Elevation views that I can't delete. Neither can I delete the Dimension line to it
    I've removed the Default Sill Height Label as we usually place windows based on a Head Height. I've added that as a label and flexed the style. Everything seems to work except I can't delete this friggin reference plane.
    All help is welcome!
    Regards,
    Reid M. Addis
    Registered Architect
    Addis Computer Consultants
    330 Bryn Mawr Avenue
    Bala Cynwyd, PA 19004
    Cell. 610-996-9666
    email: raddis@addiscomputer.com
    I could stop if I wanted to Steven Campbell's Avatar
    2003-05
    The Factory - North & some times far East
    310
    Default Re: Reference Plane - Delete
    Reid,
    I removed the reference plane and the dimension attached. You did nothing wrong it was marked not deletable which can only be changed with the internal developers tools. Sorry for the inconvenience.
    Steven M. Campbell
    Autodesk Revit
    2015-12
    208
    AHA!
    I was losing my mind!
    Ok. New problem. In the interim (interrum?) I started over with the generic Window.rfa file. I thought this would be easier and it appears to be, but now I'm stuck at how to create a "hole" or opening in the wall. I've created the glazing and frame as solid extrusions, but they are being obscured by the wall element.
    See attached.
    Regards,
    Reid M. Addis
    Cell. 610-996-9666
    2003-05
    310
    Your file already has the opening in it, but the extrusion for the glass does not have the material assigned to it so it looks like the default wall material. Just assign the material to the extrusion and it should look correct. Hope this helps...
    Steven Campbell
    Autodesk Revit
    2015-12
    208
    Well, I feel sheepish!
    Thanks!
    Regards,
    Reid M. Addis
    Cell. 610-996-9666
  1. Reference Plane as Work Plane
    By gdb in forum Revit Architecture - General
    Last Post: 2012-01-04, 03:09 PM
  2. Reference Plane?
    By rrhodes in forum Revit MEP - General
    Last Post: 2011-06-17, 05:06 PM
  3. Reference plane help
    By t1.shep in forum Revit Architecture - Families
    Last Post: 2009-12-16, 06:54 PM
  4. Family templates - delete default reference plane
    By violet78 in forum Revit Architecture - Families
    Last Post: 2009-09-01, 04:47 PM
  5. Reference Plane behaviour
    By Cheuk Ling in forum Revit Structure - General
    Last Post: 2006-07-22, 12:58 AM
