Results 1 to 8 of 8
Thread: Tag with question marks
    I could stop if I wanted to kwong's Avatar
    2002-11
    270
    Default Tag with question marks
    Hi all,
    I made a tag with a few parameters which are editable. In some instances where I want to leave a blank space I find I can't because a question mark appears instead. Is there a way to suppress the question mark as in the case of a title block tag? Thanks.
    kwong
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Default Re: Tag with question marks
    The question marks should only show when selecting the titleblock. They do not print...
    Unless of course you've actually typed question marks in...
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    2002-11
    270
    Mr Spot,
    Thanks for the reply but I think I didn't ask the question properly. I know that's the case with titleblocks, but in this case this tag I made is an electrical equipment tag and the question marks appear even when the tag is not selected, and I want to leave them blank in some instances. For now what I've done is type in a fullstop (period) in place of the question mark, but if there's a way to suppress the question mark I'd really like to know it. Thanks.
    kwong
    2004-05
    Brisbane
    1,115
    Odd i'm not experiencing that here... Shows up as blank when no value is entered on an electrical tag...
    What version of Revit are you using?
    Chris Price
    Xrev Pty Ltd
    Revit Rants BLOG
    All AUGI, all the time archjake's Avatar
    2003-07
    Tucson, AZ
    531
    Kwong,
    What version of Revit are you using? At about V7.0 a blank label will not be shown. Are you using a current version of that family? It may be an old family that didn't upgrade correctly. Delete it from your project and reload it after upgrading or using the current one from the most recent version of Revit.
    Good luck.
    2002-11
    270
    Mr Spot,
    It seems odd but 'm using 8.1, and Archjake, I've given your suggestion a try, but still no good.
    Can you think of any other reason for this ?
    kwong
    2003-07
    Tucson, AZ
    531
    Quote Originally Posted by kwong
    Mr Spot,
    kwong
    I took a (brief) second look at this. You will get a question mark when the tag is referring to the type mark of the object. In my opinion this is a good idea because it lets the user know that this object does not have a type mark associated with the object. A lot of the time this can cause scheduling problems if there are multiple objects without a type mark associated. If you have ever seen a schedule with a blank first row, this is where it is grouping all the families.
    Once you give them a type mark they will then drop down and show the values of their parameters.
    If you don't want to see the question mark I'd say turn the tag off.
    When a tag is using a custom parameter and it is not filled it it will not display the question mark unless you click on the tag.
    Hope this helps.
    2002-11
    270
    Thanks for taking the time archjake, I've had another look at your first suggestion and decided to make an entire new tag and the question marks don't appear! I compared the 2 and they appear exactly the same. Anyhow I'll just delete the offending tag.
    kwong
  1. ? Question Marks in Tags
    By brenehan in forum Revit Architecture - General
    Last Post: 2010-03-01, 08:48 PM
  2. When question marks appear in tags
    By ws in forum Revit Architecture - General
    Last Post: 2009-03-02, 11:59 PM
  3. Question Marks for empty parameters
    By jbaumann in forum Revit - Platform
    Last Post: 2007-10-04, 04:48 PM
  4. Tag with Question Marks
    By dpollard909366 in forum Revit Architecture - General
    Last Post: 2006-06-22, 07:50 PM
  5. Question marks
    By jarkko.rauvanlahti in forum Revit Architecture - Wish List
    Last Post: 2005-08-02, 02:08 PM
