Results 1 to 6 of 6
Thread: Command abbreviations - Small issue, big help
    All AUGI, all the time dpasa's Avatar
    2004-08
    Greece
    637
    Default Command abbreviations - Small issue, big help
    How can I create these 2 letters commands like "mv" for move or 'ze" for zoom extents?
    I know about keyboardshortcuts text file but the commands I want to use are under the submenu of "Host sweep" of the pulldown menu "Modeling"
    I want to make "wr" for wall reveal, "ws" for wall sweep, "se" for slab edge etc but it doesn't work, I mean when I type "se" nothing happens.
    Is it because it can't be done or did I make a mistake by replacing the default txt file with my old 8.1 after upgrade?
    Active Member swissclive54638's Avatar
    2003-10
    London
    50
    Default Re: Command abbreviations - Small issue, big help
    This is a section of the KeyboardShortcuts.txt file which will do as you require:
    "WS" menu:"Modelling-Host Sweep-Wall Sweep"
    "WR" menu:"Modelling-Host Sweep-Wall Reveal"
    It may not work if you have already got WS and WR defined in your list. Also, make sure you restart Revit after amending the file. I may be wrong, but I think it only refers to it on start up.
    I could stop if I wanted to Shaun v Rooyen's Avatar
    2005-02
    337
    Dpasa.
    Just edit the keyboard shortcuts.txt file. SE will conflict with the default SE for Snap Endpoint so be sure to change it around.
    WR & WS should work. Remember to delete the ; before "WR" eg.
    ; "" menu:"Modelling-Mullion"
    ; "" menu:"Modelling-Host Sweep-Roof Fascia"
    2004-08
    Greece
    637
    Unhappy Re: Command abbreviations - Small issue, big help
    I know what to do with the txt file, my problem is that I probably wrote my old 8.1 shortcut file over the 9.0 txt file so there are errors because there are probably changed in the menu. I guess I will have to re-install Revit (which I won't do until the next update).
    2005-02
    337
    No need to reinstall here is R9.0 keyboard txt file.
    All AUGI, all the time Arnel Aguel's Avatar
    2003-05
    Philippines
    577
    If you created a shortcut and unknowingly a duplicate already exist when you type the letters for the shortcut but nothing seems to happen LOOK AT YOUR STATUS BAR If the hotkey is shown that means your shortcut is active but there is a duplicate, press your left or right arrow key and it will toggle to the duplicated shortcut then it's to time to edit which one would you like to retain.
  1. command issue
    By kcheong in forum AutoCAD General
    Last Post: 2010-05-03, 01:48 PM
  2. small copy issue
    By Rico in forum AutoCAD General
    Last Post: 2008-08-14, 01:32 PM
  3. List of Abbreviations
    By cadkiller in forum CAD Management - General
    Last Post: 2006-08-16, 09:10 PM
  4. Abbreviations list
    By ashuler in forum Revit Architecture - General
    Last Post: 2006-02-21, 03:58 PM
