Results 1 to 10 of 10
Thread: Opening drawings in windows taskbar
    2004-01
    On Earth Today
    29
    Default Opening drawings in windows taskbar
    Hi everyone
    I had to reinstall ADT 2006 and lost some of my custom settings. One of the setting which I really miss is the ability to open multiple drawings the windows taskbar at bottom of the screen and act a separate applications.An example of this would be if you had 3 drawings open each would be a tab in the windows taskbar.
    I have forgotten how I did this or what switch I turned on or off
    any help would be appreciated
    Thank you
    2001-12
    St. Louis
    5,412
    Question Re: Opening drawings in windows taskbar
    "TASKBAR" ?
    Quote Originally Posted by blanni
    Hi everyone
    Thank you
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2004-01
    On Earth Today
    29
    Default Re: Opening drawings in windows taskbar
    The windows taskbar at bottom of screen, where the program names goes to when you minimize a program or listing of programs running when several are being used. Some have it along the bottom of the screen.
    Maybe I did not explain myself clearly, when one opens several drawings each are nested in the main drawing screen window. There is a switch which will cause ADT to open a drawing as if to start a new version of the ADT program to run.. This allows you to switch between drawings just by clicking on the appropriate drawing name in the taskbar.
    Hope this helps
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,124
    Hope this helps
    Did you have a look at the SYStem VARiable, TASKBAR?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    As in (from the help file):
    Controls how drawings are displayed on the Windows taskbar
    Command line: taskbar
    Enter new value for Taskbar <0>: Enter 1 to display multiple open drawings as separate items on the Windows taskbar
    The default setting, 0, displays only the name of the current drawing on the Windows taskbar.
    13,656
    <SNIP>
    Hi "blanni" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    Active Member bbacker's Avatar
    2003-03
    NM
    57
    Thumbs up Re: Opening drawings in windows taskbar
    oh that is slick!
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Quote Originally Posted by Wanderer
    "TASKBAR" ?
    With a new hard-drive, I lost or "forgot" many of the old setting too, including this one. Doing a search throughout the forums helped!
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,261
    Wink Re: Opening drawings in windows taskbar
    Sounds like an updated version of that old Abbot and Costello routine.
    Abbot: What is that setting for getting multiple drawings listed on the taskbar in AutoCAD?
    Costello: "TASKBAR"
    Abbot: Yes, the drawings should be listed individually on the taskbar. What is the command?
    Costello: "T A S K B A R"
    2001-12
    St. Louis
    5,412
    Talking Re: Opening drawings in windows taskbar
    you're our newest poster child for the benefits of searching. thank you.
    Quote Originally Posted by Maverick91
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Opening drawings from Windows Explorer
    By ndileepn in forum AutoCAD General
    Last Post: 2009-05-07, 09:23 AM
  2. Search text within drawings, without actually opening drawings
    By Animesh Kundu in forum AutoCAD General
    Last Post: 2008-02-29, 05:34 PM
  3. Replies: 8
    Last Post: 2007-08-06, 02:58 PM
  4. Opening drawings
    By Joe Seppy in forum AutoCAD General
    Last Post: 2007-08-03, 12:41 PM
  5. Open DWGs on Windows XP Taskbar
    By tomcarver in forum AutoCAD General
    Last Post: 2006-10-19, 09:52 AM
