Results 1 to 10 of 10
Thread: New and want to use mental ray - any good exterior tutorials out there
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    Unhappy New and want to use mental ray - any good exterior tutorials out there
    I have used viz and am fairly familiar with radiosity but i want to move into the mental ray engine. I have done the tutorial in the help but found that it doesn't really help me out with exterior renderings. Is there any one out there with a good exterior tutorial? Is there any settings that need to be changed in viz that i might not be doing to go from scanline to mental ray? I seems that my rendering are always missing light (large black spots, or no light at all).
    I have seen some great stuff from mental ray, and want to do the same.
    any help appreciated.
    Thanks
    Justin
    I could stop if I wanted to dellis's Avatar
    2003-12
    Windsor, Ontario, Canada
    379
    Default Re: New and want to use mental ray - any good exterior tutorials out there
    Justin,
    Which version of VIZ are you using? The new version of mental ray is alot easier to handle and produces great results.
    2004-07
    954
    I posted this question with v2006. i just got my new 2008 today and looking forwarding to using it. hopefully the new mental ray is as easy as you say.
    Thanks
    Justin
    All AUGI, all the time Arnel Aguel's Avatar
    2003-05
    Philippines
    577
    Hi Justin here are a few good ones from mental ray gurus
    Jeff Patton
    Shane Griffith
    Hope this helps
    I could stop if I wanted to rmejia's Avatar
    2006-10
    Puerto Rico
    432
    Here are two more links for Mental Ray tips:
    http://www.mymentalray.com/
    http://mentalraytips.blogspot.com/
    2006-11
    2
    Does anyone recommend any other 3rd Party Render programs other then mental ray ?
    2003-12
    379
    I personally can't live without VRay!!!!
    2007-10
    5
    Has anyone timed the new Metal Ray version with V-ray? I am assuming quality is comparible. Any experience with ease of use between the two?
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,280
    Quote Originally Posted by cuptmor View Post
    Haha, I timed how long it took to write a check for VRay and how long it took to open up the free MR from Max...
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2003-12
    379
    As far as usability....now, finally, mental ray has an interface that is pretty straight forward and usable. Ironically, it looks alot like VRays UI. As far as quality i would say that MR is up there with the top renderers...but all the available rendering engines can produce stunning work....depends mostly on who's driving it. Now speed is one of those things that is really specific to what you have going on in your scene. From my experience i've found that VRay is faster especially as the scene gets more complex. I definetly encourage you to try out your own benchmarks though.
  1. has anyone found any good books or tutorials
    By david.i.wells788433 in forum Parts Builder
    Last Post: 2011-03-27, 06:56 PM
  2. Any good tutorials on rendering and lighting?
    By ROBinHI in forum Revit Architecture - General
    Last Post: 2010-04-01, 07:35 AM
  3. Why use Mental Ray
    By kbodesign in forum 3ds Max - mental ray
    Last Post: 2008-10-30, 02:36 PM
  4. standalone mental ray vs. 3ds Max's internal mental ray
    By stusic in forum 3ds Max - mental ray
    Last Post: 2007-04-17, 04:18 PM
  5. Good tutorials or books for VBA programming on AutoCAD
    By curime_batliner in forum VBA/COM Interop
    Last Post: 2006-11-01, 06:05 PM
