Thread: Xref Layers not staying frozen when reloaded?
    Dynamic Blockhead Mod Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Xref Layers not staying frozen when reloaded?
    When I attach an Xref, I freeze layers that I do not want to see and begin drafting.
    Somewhere along the line, I decide that something in the root Xref drawing requires modification. I open it up, make my changes and save.
    I go back to the drawing with the attached Xref. The Xref manager tells me that it needs reloading.
    So far so good.
    Here's where my problem is:
    When I reload the Xref, it reloads everything. INCLUDING the layers I froze. I freeze these layers again and continue drafting. But every time I reload an Xref, it unfreezes frozen layers.
    It's really irritating to have to go and freeze 30 layers every single time I reload an Xref. Especially when a co-worker is working on the Xref.
    Is there a setting to prevent this from happening? Or to control this behaviour?
    I tackled this once before and can't remember how I solved this issue.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: Xref Layers not staying frozen when reloaded?
    Look at the VISRETAIN variable. I believe it should be set to 1 for what you are wanting.
    2005-06
    1,828
    Quote Originally Posted by Opie
    That's what it was. Thanks Rich.
    [SIGPIC][/SIGPIC]
    2002-01
    jUSt Here (a lot)
    6,836
    Glad to help.
  1. Xref not staying in background
    By amsterdamn in forum AutoCAD General
    Last Post: 2008-08-27, 02:28 PM
  2. XRef - Frozen Layers
    By kparr in forum AutoCAD General
    Last Post: 2008-06-20, 11:48 AM
  3. When updating xref, frozen layers thaw
    By mark.momper in forum AutoCAD General
    Last Post: 2008-03-18, 08:39 PM
  4. Frozen Layers within Xref come in Unfrozen
    By mcoffman in forum AutoCAD General
    Last Post: 2006-06-14, 02:14 PM
  5. Replies: 3
    Last Post: 2004-07-02, 07:25 PM
