Results 1 to 10 of 13
Thread: How can I know which linetypes definition file was used to load linetypes?
    2003-08
    Tijuana
    225
    Default How can I know which linetypes definition file was used to load linetypes?
    2001-05
    Austin, TX USA
    2,201
    Default Re: How can I know which linetypes definition file was used to load linetypes?
    As far as I know there is no way of finding that out.
    100 Club a_meteni's Avatar
    2002-12
    Cairo
    174
    I think it depends on the units of the drawing file whether imperial or metric
    Earth
    9,804
    I agree with Glenn. There is no way to find out. In fact, it's possible to create linetypes without even using a .LIN file.
    As for the reply from a_meteni, I think that is a reference to "acad.lin" vs. "acadiso.lin". Still no guarantee a linetype definition came from either of those files.
    R.K. McSwain | CAD Panacea |
    0,0,0 The Origin
    8,570
    If it IS a choice between acad.lin and acadiso.lin, just start to load another linetype and see which file is offered in the list box.
    Earth
    9,804
    Quote Originally Posted by jaberwok
    Still no guarantee. That just points to the last used LIN file, right?
    A DWG file could have linetypes loaded from both "acad.lin", and "acadiso.lin"
    Another idea for sifuentes, download TO-LIN.LSP from http://www.turvill.com/t2/free_stuff/index.htm - this will create a LIN file from any linetype definition in the drawing. Then you can compare this file to the various LIN files to which you have access.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by rkmcswain
    Yes. True. But it usually helps to look at the simple cases first.
    2003-08
    Tijuana
    225
    I was hoping I could find out wether the linetypes had been loaded from acad.lin or acadiso.lin. The Load or reload linetypes dialog box defaults to acad.lin, regardless of which .lin you used last.
    13,656
    Hi
    The following thread might be of some interest to yourself...
    Which .lin file has a Linetype come from
    Plus, you might try plugging the following search criteria into the forum search facility...
    Key Word(s): *Measurement* + *Linetype*
    *Measurement* + *Acad*
    Have a good one, Mike
    Earth
    9,804
    Quote Originally Posted by sifuentes
    As noted above, you are not going to be able to identify the source LIN file (if any) from simply looking at the drawing - that info is not saved in the drawing.
  1. 2014: Linetypes Bad Definition
    By Iceberg in forum AutoCAD General
    Last Post: 2014-04-07, 07:15 PM
  2. Loading standard linetypes - Bad definition
    By Richard McDonald in forum AutoCAD General
    Last Post: 2006-10-24, 08:07 AM
  3. Custom Linetypes not loading - Bad definition at...
    By The VLG in forum AutoCAD General
    Last Post: 2006-07-07, 02:06 PM
  4. Linetypes with shapes - Error: bad definition at line...
    By Coolmo in forum AutoCAD Customization
    Last Post: 2006-01-18, 02:20 PM
