Thread: Invisible Dimensions
    All AUGI, all the time davidcobi's Avatar
    2005-03
    Greater Los Angeles
    546
    Default Invisible Dimensions
    We have a user that wants to lock a wall half way between two points and doesn't want the dimension string to plot. The best I can do is set the two dimensions EQ and make a special dimension type with white lines, no tick marks, and very small text. Can anyone think of a way to make a dimension invisible? Can't add a subcategory to dimensions in Object Sytles either.
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: Invisible Dimensions
    Duarte
    make the dim string > use EQ or Lock > delete the string > Revit will ask you if you want these elements to remain constrained or not. > choose Ok.
    2005-03
    Greater Los Angeles
    546
    Thanks Eddy.
    2001-12
    Irvine, CA
    7,567
    Tossing in 2 pennies,
    Since these walls will remain constrained invisibly that might come back to bite someone later. For example a tall building where someone locked the distance between floors and then later deleted the string. Now someone else tries to change the floor to floor height and gets error message after error just because the constraint is still there and they didn't notice the telltale green dashed line...yadda yadda...
    If this sort of constraint is really important then consider making a duplicate view called Level 1 - Constraints (or somesuch) Lock and constrain it there...now everyone can see the constraints anytime they want and see why they are there because you can add a note saying so.
    2005-03
    Greater Los Angeles
    546
    This is a new user. I think he's starting to realize that constraints in a project file are more trouble than they are worth. Interesting idea about putting contrants in a separate view though.
    2011-11
    19
    Quote Originally Posted by eddy.lermytte View Post
    Duarte
    Quote Originally Posted by Steve_Stafford View Post
    Nice tips from both of you. Still gotta side with Steve_Stafford. He has a point there with losing track of previously placed constraints...
  1. Aligned dimensions acting like linear dimensions (only up-down, left-right on page as viewed)
    By browns.joseph308864 in forum Revit Architecture - General
    Last Post: 2011-12-07, 01:48 AM
  2. Replies: 3
    Last Post: 2006-09-20, 05:14 AM
  3. Invisible temporary dimensions when performing a Linear Stretch
    By ron.sanpedro in forum Dynamic Blocks - Technical
    Last Post: 2006-05-24, 12:18 PM
  4. Invisible Dimensions
    By jspagac in forum AutoCAD General
    Last Post: 2006-01-05, 03:04 PM
  5. Invisible line shouldn't be invisible
    By WolffG in forum Revit Architecture - Wish List
    Last Post: 2003-12-19, 01:23 PM
