Results 1 to 10 of 11
Thread: Flatten Z cords without using the Flatten command.
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    297
    Default Flatten Z cords without using the Flatten command.
    Anyone put there found a easy way to remove the z co-ords from lines etc without having to use the flatten command. I tried flatten and it sent the machine into overdrive and still didn't complete the job properly.
    CAD RAT AKA Mr dribble, AKA Grumpy Old Man.
    2001-03
    13,499
    Default Re: Flatten Z cords without using the Flatten command.
    2004-08
    Hartford, Michigan
    3,086
    change the z elevation in the properties palette
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    Active Member a_meteni's Avatar
    2002-12
    Cairo
    52
    But change elevation only works with objects having the same Z value . if your object having different Z values u'll need the flatten command
    Regards
    0,0,0 The Origin
    8,027
    Quote Originally Posted by ccowgill
    Quote Originally Posted by a_meteni
    Not necessarily.
    For example, the z-value for each end of a line can be altered in the properties manager.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Houston
    7,519
    Quote Originally Posted by glyn.ratcliffe
    You might want to try this:
     (command "._move" (ssget) "" '(0 0 1e99) "" "._move" "_P" "" '(0 0 -1e99) "")
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Land Desktop has a "Flatten Z Values" command. This question comes up so often, maybe we need a Wishlist item to move this command from LDD to Vanilla Autocad?
    ATP Manager CADKitty's Avatar
    The Dragon's Lair
    730
    Simple - do what I do.
    At the command line:
    change>properties>all>elevation>0>enter
    I always seem to get hit with "lines are non-coplanar" messages, so that always does the trick!
    Hope it helps!
    Back in the AutoCAD saddle and loving every minute!
    100 Club Jeepin's Avatar
    2003-11
    The Woods
    122
    I agree w/ CadKitty. Or just a plain "move" command will work. move items from 0,0 to 0,0,0. For us civil geeks, this is an easy way to lift or lower grade lines one foot. Rich
    2003-11
    The Woods
    122
    I apologize for another post, but I just remembered that someone came to me last week because he couldnt get the flatten command to work and the line he snapped too had a z elevation of .00006 so sometimes moving to just "0" doesnt help, you might have to change the unit precision or put a lot of 0's after a decimal point. Rich
  1. Flatten
    By lgoff in forum AutoCAD Customization
    Last Post: 2011-06-28, 01:26 PM
  2. Problem w/ Flatten command
    By cwjean76 in forum AutoCAD General
    Last Post: 2008-04-16, 04:54 PM
  3. Replies: 12
    Last Post: 2006-12-08, 05:37 PM
  4. Flatten Command or equivalent
    By fdebolt in forum AutoCAD General
    Last Post: 2006-09-22, 12:10 AM
