jcdecastro
Has anyone come up with a set of naming conventions or standards for naming object styles?
This issue comes up both at the project level and at the component level. In the project your detail and model lines need to be categorized and in the components, although once you categories your component properly the object styles are placed in the correct category but the larger the project gets and the more users on the project the more potential for names to get out of control.
For example: if I were to create a specialty equipment component: FUME HOOD. Should I name the name the object style for the plan lines FUME HOOD PLAN or useto the CAD Standard and name it A-EQPM.
The View Template feature also comes into play here because if there were a set of standards, implementing view templates would be easier. I say easier because if there is no convention and new object styles get added after a view template is applied you either have to fix the object styles one by one or keep making new templates.
So does anyone have a convention or suggestion?
