I just came across something I that has been under my nose and maybe yours too! When pressing tab to cycle through the different objects you can select, there are times where you will cycle past what you want to select. When this usually happens, you need to keep pressing tab to go through the cycle again.
If you hold down shift and then press tab, you will cycle backwards. I don’t know if this has been posted before but it is always a good reminder.
Happy Reviting!
