View Poll Results: I think print Previews
Voters
22. You may not vote on this poll
  • Take too long - I want the instant thumbnail view
    11 50.00%
  • Take too long - I want it sped up
    6 27.27%
  • Are fine.
    3 13.64%
  • I dont use it.
    2 9.09%
Results 1 to 10 of 16
Thread: Print Preview Thumbnail
    2003-04
    Scotland
    1,577
    Default Print Preview Thumbnail
    Print Previews take AGES in Revit. I would really like to be able to get an instant preview thumbnail like there is in Autocad or Acrobat etc to simply confirm what the area of the sheet being taken up is. The Autocad method is very good as it is just a block showing the area.
    I hate the print preview at the moment as it takes an eternity to preview to find out you are actually printing wrong - then you have to do it again!! lets change it ASAP please
    2003-04
    Scotland
    1,577
    Default Re: Print Preview Thumbnail
    Ok. I wish I hadnt added that option.
    They are not fine - they take too long - much longer than anything else I use.... therfore they arent fine.
    I am getting tired of this.
    2002-02
    St. Louis, MO
    4,695
    You use the print preview?
    I always considered the sheet itself the print preview....
    2003-04
    Scotland
    1,577
    Well, mostly I try not to for the above reason!!... occasionally though I dont trust myself to have set everything right and press the preview button - then instantly wish I hadnt bothered as it slowly, slowly, slowly regenerates a little bit at a time - only to show me that I have set up my sheet wrong.... So I suppose I dont use it that much, but only because its such a pain in the .... to do so.
    I dont mind you picking that option Aaron Sometimes just get tired of the single vote from the "not a problem" phantom that seems to lurk the wishlist sometimes...Phantom, dont you know that option is usually only put there to be polite? - its not meant to actually be picked!! If its on the wishlist - somebody thinks its a problem, so dont pick it!! LOL...for the avoidance of doubt, I am joking!
    2005-08
    49
    I use preview on regular bases i.e. when I need to print just small portion from actual sheet or directly from the view (it's just sometimes easier to take little print with comments to boss than the whole screen..).
    I'm not too keen on improving preview, but I'm keen on getting print area - tool (AutoCAD print window) to print any specific spot on view or sheet. The printing option Visible portion of the view is never actually same as you see on screen and going back and forth between print preview and View is frustrating..
    I could stop if I wanted to Dean Camlin's Avatar
    2002-11
    Westminster, MD, USA
    354
    Quote Originally Posted by aaronrumple
    Unfortunately, the way text sometimes behaves, WYSINWYG, and you have to use the print preview to see how it will turn out.
    2003-04
    Scotland
    1,577
    Quote Originally Posted by jarkko.rauvanlahti
    If you make the view into a "Window" (ie not minimize of maximize, the other one.) The window extents are the extents of the print - if you know what I mean... Strange thing to say that you are frustrated with previewing in Revit - but that you arent keen to improve it !?
    All AUGI, all the time BillyGrey's Avatar
    2004-04
    in a calm assertive state
    638
    Heavens to mergatroid, don't try this with lots of shadows on...
    2005-08
    49
    Quote Originally Posted by Martin P
    The window extents haven't been the extents of the print - close but never exactly same and some part gets missing - we usually print A4 or A3 and that's almost never size of the plan print. there's also many cases where I need just small detail in different scale.
    If I would get print area tool I wouldn't need preview any better from now - for normal preview of sheet it's ok.
    2003-04
    Scotland
    1,577
    This should print exactly the window if its not maximized, if you pick visible portion in print. Are you saying that sometimes it does match 100% using this method? I dont use it very often, but it usually seems to work?
    I do prefer the the method where you draw a window though and agree it would be good to add it, .
  1. Thumbnail Preview from memory
    By sresh in forum Dot Net API
    Last Post: 2015-06-05, 03:18 PM
  2. Preview Thumbnail Save
    By dbartlett in forum Revit Architecture - Families
    Last Post: 2010-10-11, 07:38 PM
  3. Element Thumbnail Preview
    By dmoodydesign in forum Revit Architecture - General
    Last Post: 2009-07-06, 03:00 PM
  4. Groups - thumbnail preview
    By J. Grouchy in forum Revit Architecture - Wish List
    Last Post: 2004-08-20, 01:00 PM
  5. Preview thumbnail default on
    By Nic M. in forum Revit Architecture - Wish List
    Last Post: 2004-06-08, 09:30 AM
